#303976 03/20/14 11:41 AM
Rich33 Offline OP
This there a template a for dash clock location for 1933 Chevy Master Coupe. Before i drill a hole in dash i would like to know where it is to be properly located. can anyone help?
Rich33
1933 5 Window Chevy Master Coupe
1951 1500 Chevy Truck 5 Window
1968 Chevy Camaro
Rich33 #303981 03/20/14 12:30 PM
I thought all the clocks were in the rear view mirror. either string pull winder, stem winder or electric.
The 33 master doesn't have glove box like a 34 to install it in. So its pick a spot. If it was a dealer installed accessory, then its wherever you eyeball it to be. I do not think there was ever a template, just hole saw the hole and install.
mike Agrin
If you must make a hole try to use a hole punch, it makes a cleaner job of it.
J Franklin
A 1/2 inch hole is all that is required to mount the correct 33 clock. I placed my clock in the middle of the mass on the right hand side of the gauge cluster.
You will be required to place a switch/fuse in the line to the clock. It will not take too much time to deplete your battery.
Agrin devil
Unfortunately, a large percentage of us backyard mechanics do not own hole punches. But we do own hole saws wood and metal.
mike
Agrin devil
Only a 1/2 hole to mount the clock obviously to the surface, I gotta see this 33 accessory clock..............how about a picture by original poster.
mike carbana
Rich33 Offline OP
If you send me your email i will send you a picture. I cant seem to post a picture yet. Mine is rmelius@venturafoods.com
Rich33
1968 Chevy Camaro
Rich33 #303993 03/20/14 04:07 PM
Here are three views of the '33 dash clock that Rich33 sent.
[Linked Image from i1264.photobucket.com] [Linked Image from i1264.photobucket.com] [Linked Image from i1264.photobucket.com]
The last photo shows how the half inch hole plays into it.
Roger
How about I sell you one so you can check it out with your own eyes? I have several of the 33 clocks for sale.
Agrin devil
Agrin devil
thanks for the offer but I will be running a rear view mirror stem wind clock mirror in my 35 std roadster , same as I am running on my 35 std coupe.
Even looking at that clock makes no sense to me exactly how the 1/2' hole makes it mount on or in , the dash
mike ref
