oldcarz Offline OP
1. Does anyone have a mounting template for this heater that I can borrow to copy?
2. Does anyone have the temperature gauge fitting for the engine block for sale or know of a modern day replacement?
3. Does anyone know the value of the resistor on the heater switch?
4. The installation instructions state the heater switch should be placed in a convenient position on the dash panel. Where was was it usually placed? Thanks.
The heater switch was placed in a "convenient" location on the instrument panel which basically means that it was installed anywhere that the customer wanted. However, all of the original switches that I have seen were installed on the passenger side of the instrument panel to the right of the gauges.
Check Ebay for the fitting. One just sold for $9.95.
oldcarz Offline OP
Thanks Skip.
oldcarz Offline OP
Steve,
I saw one on ebay also but was not sure it was the right one. It went for about $45. I will keep an eye out anyway. Thanks.
You might also want to post an ad in the parts wanted forum.
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
I have some of the mounting information that you want... I'll try to dig it up and post here later.
Bill Barker
(VCCA Member: 9802)
I have a cowl assy. and checked for the heater holes which it has , but they are not correct for the 31 heater. I did however while checking find a temp sender fitting that is not the greatest, but may be functional. It will need to be cleaned up so I can check it to be sure it's worth shipping. Should be able to do that tomorrow and will let you know if it is still usable.
oldcarz Offline OP
Thanks Bill & Steve.
The 1931-2 heater installation information including a 1/2 scale template was published in the February 2005 pages 30-32.
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
Okay, I've used this as my trigger for a new section in the MEMBERS area (http://vcca.org/members/)
Under RESOURCE CENTER there is now a new folder called "Installation Instructions".... and under that is a bunch of files for 1931, 32, 36 and 37 Hot Water Heater instructions AND diagrams.
Good luck.
--Bill
PS. More coming soon... probably later tonight.
oldcarz Offline OP
Thanks Chipper. I know I have that issue, it will just be a matter of digging it out.
oldcarz Offline OP
Thanks Bill for all you do.
