Page 2 of 2 1 2
Just add some food for thought, my interchange manual says that a 1930 Chevy transmission was also used by GMC 1927-28 T11 trucks and Pontiac 1926-28. So it is possible that the transmissions with the extra holes maybe a GMC or Pontiac transmission. Things get changed over the years so you never know what might be on your car.
Okay.....I went out and measured the U joint ball retainers that I have and....you are right.....they are all the same length. Man, by eye it sure looks like the retainer with the two extra holes is longer than the retainer without the two extra holes. Sure is deceiving!
I was just up and looked at my 1929 Sedan and the two holes that are in 63 SWC transmission are for the bracket that supports the middle of the brake cross shaft and bearings.
Great! That is what we needed to know. Here is another case where the Chevrolet part was changed but the part number remained the same. The part number for the retainer is the same from 1929 thru 1931 yet, from what you found, the retainer for 1929 is different than the retainer for 1930 and 1931.
63_SWC Offline OP
And the winner is Andy !!The riddle is solved.
I looked at the parts book and found like Andy said there are several differences in the brake rods at that point.
Thanks, Larry.
The '28 transmission looks like the '29 with the two holes for the brake cross shaft support. They differ as the speedometer cable is on opposite sides.
Sorry am Behind...
Is this what you are referring to in regards to the Two Tapped Holes in the Transmission and the Bracket (Brake Cross Shaft) they Support ??
Transmission 1
Transmission 2
These are from my 1929 4 dr sedan...
Now that we have cleared up just what the holes are for (I personally have never seen these on a U-Joint retainer), it is interesting that the '29-'32 parts price list shows the retainer (part #590406) as being the U/J retainer for '29,'30 and '31, and the illustration on page 34 shows the part as having the 2 extra holes for mounting the earlier brake cross shaft bracket. These holes do not exist on the case for my '31 Coach which has a '30 Transmission. I guess we can conclude that at some point the part was manufactured without the extra holes, likely once the "brake cross shaft support bracket" was no longer used. Not sure just when that occured. Later price lists may list both the earlier and later retainer.
Yep....that's it!!
Thanks for posting the photos.
The 1934 parts book shows the same part number and it also has a photo of the retainer with the same two holes as well.
Page 2 of 2 1 2
