U-joint housing lube level - 01/13/14 12:58 AM
I replaced my drive shaft bushing and noticed that my u-joint housing is missing what must be a fluid level check plug.
Is that what the hole directly behind the speedometer cable is????
I plugged this hole and filled the u-joint housing with 8 oz of gear lube.
As usual I could not find anything in the owners manual or the repair manual.
Thanks, Larry.
Thanks, Larry.
