What is the difference in the frames from the delivery and 2dr,4dr sedans if any ?
i've got a 39 sed del and although i'm not 100% certain, i'd guess there is no difference in the frames . mike
There are indeed differences in the frames. I have a 1938 panel truck, and its frame is different (as is the pickup frame) from the car frames. The panels (and I assume the sedan deliveries) came in different weight classes, 1/2 ton, 3/4 ton, and 1 ton, and even those frames have some differences among themselves. I know that the 3/4 ton and 1 ton panel frames are the same, BUT the size of the rear brakes are different on those two. There are other differences as well, most obvious the wheelbases. I have a spare 1939 1-ton frame, if anyone is interested.
Jim
Not so fast Masked Man. The 1939 Sedan Delivery and Master 85 used the same Series JB 112 1/4" wheelbase frame. Not the same as JC 113 1/2" 1/2 ton frame or JD (11" brake) and JE (14" brake) 123 3/4" 3/4 ton frame.
A sedan delivery is built on a passenger car chassis. It looks the same as a car of that year but has an enclosed body.
A panel truck is built on a truck chassis and looks like a truck as far as the front end sheet metal is concerned.
A sedan delivery frame will be the same as a passenger car of that year. In 1939 the sedan delivery was on the lower priced Master 85 chassis which had leaf springs in the front. No sedan delivery was available in the deluxe model with a coil spring front suspension.
That being said there is no reason a sedan delivery body could
not be mounted on a delxe model frame.
Sorry, I stand corrected. I was thinking the sedan delivery was comparable to the panel, and obviously I was wrong. Thanks for setting it straight.
Jim
Common error. Especially for the young guys like you wave
If I had a nickel for every time I had to explain that to people who visit, both of my sedan deliveries would be done...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
Thanks everyone for the info it helps a lot.
Let me know if you need and delivery parts, i have owned a few over the years, and have spare inside wood/metal braces, corners, rear door lock.
and a used rear spare tire floor
DUKES CAR CLUB, EST:1962
VCCA#036554
