Posts: 154 Likes: 1
Posts: 154 Likes: 1 |
What is the difference in the frames from the delivery and 2dr,4dr sedans if any ?
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
i've got a 39 sed del and although i'm not 100% certain, i'd guess there is no difference in the frames . mike
Posts: 434 Likes: 1
Posts: 434 Likes: 1 |
There are indeed differences in the frames. I have a 1938 panel truck, and its frame is different (as is the pickup frame) from the car frames. The panels (and I assume the sedan deliveries) came in different weight classes, 1/2 ton, 3/4 ton, and 1 ton, and even those frames have some differences among themselves. I know that the 3/4 ton and 1 ton panel frames are the same, BUT the size of the rear brakes are different on those two. There are other differences as well, most obvious the wheelbases. I have a spare 1939 1-ton frame, if anyone is interested.
Jim
Not so fast Masked Man. The 1939 Sedan Delivery and Master 85 used the same Series JB 112 1/4" wheelbase frame. Not the same as JC 113 1/2" 1/2 ton frame or JD (11" brake) and JE (14" brake) 123 3/4" 3/4 ton frame.
A sedan delivery is built on a passenger car chassis. It looks the same as a car of that year but has an enclosed body. A panel truck is built on a truck chassis and looks like a truck as far as the front end sheet metal is concerned. A sedan delivery frame will be the same as a passenger car of that year. In 1939 the sedan delivery was on the lower priced Master 85 chassis which had leaf springs in the front. No sedan delivery was available in the deluxe model with a coil spring front suspension. That being said there is no reason a sedan delivery body could not be mounted on a delxe model frame.
Posts: 434 Likes: 1
Sorry, I stand corrected. I was thinking the sedan delivery was comparable to the panel, and obviously I was wrong. Thanks for setting it straight.
Jim
Common error. Especially for the young guys like you
Posts: 3,163 |
If I had a nickel for every time I had to explain that to people who visit, both of my sedan deliveries would be done...Joe
Posts: 154 Likes: 1
Thanks everyone for the info it helps a lot.
Posts: 166 |
Let me know if you need and delivery parts, i have owned a few over the years, and have spare inside wood/metal braces, corners, rear door lock. and a used rear spare tire floor
DUKES CAR CLUB, EST:1962
VCCA#036554
