Posts: 8 |
Hi, I'm from Argentina, I wonder if the cab of the pickup model 1936 is equal to the pick up 1937. apologize for my English. thanks
Posts: 1,294 |
No. The 37 was the first year for an all steel body. They are two different cabs.
Posts: 8 |
measures are different? height, width, windshields, windows, doors
According to parts book. If you bought a new cab for a 1934-1937 truck you got a 1937 cab. When mounting the 1937 cab on a 1936 chassis you needed the following: gas tank and related parts, instrument panel and gauges, floor and toe board parts.
Posts: 8 |
I want mounting the 1937 cab on a 1936 chassis.that's why I want to know if you have the same measures
Posts: 8 |
oops.the 1936 cab on a 1937 chassis
Should work either way. There are two design cabs in 1936 Early had little built-in visor above windshiels and late was smooth. The late looked more like a 1937 cab.
Posts: 8 |
well sorry for not understanding English language ... but not the same the cab?
Posts: 8 |
Not same but will "fit" on chassis.
Posts: 8 |
measures are very different?
