#287906 08/29/13 09:16 PM
1977 Offline OP
Hi, I'm from Argentina, I wonder if the cab of the pickup model 1936 is equal to the pick up 1937. apologize for my English. thanks
No. The 37 was the first year for an all steel body. They are two different cabs.
1977 Offline OP
measures are different? height, width, windshields, windows, doors
According to parts book. If you bought a new cab for a 1934-1937 truck you got a 1937 cab. When mounting the 1937 cab on a 1936 chassis you needed the following: gas tank and related parts, instrument panel and gauges, floor and toe board parts.
1977 Offline OP
I want mounting the 1937 cab on a 1936 chassis.that's why I want to know if you have the same measures
1977 Offline OP
oops.the 1936 cab on a 1937 chassis
Should work either way. There are two design cabs in 1936 Early had little built-in visor above windshiels and late was smooth. The late looked more like a 1937 cab.
1977 Offline OP
well sorry for not understanding English language ... but not the same the cab?
1977 Offline OP
but not same the cab?
Not same but will "fit" on chassis.
1977 Offline OP
measures are very different?
