Folks,
I am trying to document radiator identification for early six cylinder era Chevrolets. Can any of you help filling in the question marks. As an introduction the model number is reverse stamped into the top radiator tank as is the date code. The date code is last two digits of year then letter for month. If date code is another format or order please correct.
1929 Make = Harrison "Hexagon" honeycomb Model = ???? Size = 3/8" cells??? Date code = YY M???
1930 Make = Harrison "hexagon" honeycomb Model = ???? Size = 3/8" cells Date code = YY M
1931 Make = Harrison "hexagon" honeycomb Passenger & ½ ton Model = 3053 - 34 sections of 3/8” cells Date code = YY M 1 ½ ton truck Model = 3054 - 36 sections of 5/16” cells Date code = YY M
1932 Make = Harrison "hexagon" honeycomb Passenger Model = 3088?? - ?? sections of 3/8” cells Date code = YY M 1/2 ton Model = 3053?? - 34 sections of 3/8" cells Date code = YY M 1 ½ ton truck Model = 3088?? - ?? sections of 5/16” cells Date code = YY M
1933 Make = Harrison cellular Model = ??? Date code =
Feel free to add any additional years and models. Hopefully this will lead to a means to identify the correct radiator for all years, makes and models.
Posts: 3,163 |
Chipper I can help you with 1933 Master & Standard. I also have 1934 Master. I can get that for you later...maybe tonight...Joe
Posts: 558 |
I have a 32 with the original radiator so I will look tonight to check for you.
Posts: 1,966 |
Mine (from a '31) is the Harrison 3053, dated 31 E. It leaks bad, so I have installed a honeycomb aftermarket unit from the 60's specifically made for '31 Chev. A question I have is regarding neck length. I have the Viking flip top ornamental rad cap which fits fine on the aftermarket tank, which has a neck about 3/8" to 1/2" longer than the Harrison neck. Did all Harrisons of this period for Chevrolets have same neck height (on mine it is 5/8" above top of rad sheetmetal (not tank) and flush with opening in rad shell)?
Posts: 3,163 |
Chipper I have the 1933 radiators here & I'll get the 1934 soon.
1933 Master is 31001. I have 2. "33 A" & "32 L". It has 40 rows 3/8 wide.
1933 Standard is 31002. I have a "33 A" (Earliest date known) It has 33 rows 3/8 wide Joe
Thanks Joe particularly for the '33 Standard. You are one of the few that could supply that number.
How about all you '32 owners? Skipper did you check your original '32 passenger radiator tank?
Posts: 151 |
Mine is 3088-32D Hexagon.
kerry j camp
So that means 3088 is confirmed as 1932 passenger radiator top tank. Now we just need to verify that is uses 3/8" hexagons and there are ??? rows. Also need to ID the 1/2 ton (fits into a '31 style shell) and 1 1/2 ton radiators.
Posts: 179 |
Chipper, My '34 Standard has Harrison 31021 and is stamped 34 under that which I suppose is the year? Dan
Posts: 1,896 Likes: 28
Posts: 1,896 Likes: 28 |
I have a 30 with # 3052, dated 30 D.
Posts: 977 Likes: 7
Posts: 977 Likes: 7 |
Bill Masters
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
I have 2 1932 radiators which i can get to . 3088 32 D has 62 rows of hexagonal.( originally from here in AUSTRALIA ) I also have one with a diamond pattern (possibly a replacement) 3088 32 B (originally From USA)
JACK
Posts: 191 |
My '32 has tank 3075 with date code 31 K. It's been recored to fin and tube.
Posts: 980 |
29 E 3008 29 H 3009 31 C 3053 31 F 3053 31 L 3075 32 L 3092 33 F 3092 (CB chassis Sedan Delivery)
If you have old Chevrolets, other old Chevrolets will find out where you live.
Posts: 977 Likes: 7
Does anyone know what year and model a radiator with 31019 is for?
Bill Masters
Bill, First clue will be the date code stamped on the top tank.
Dave, Do you know if one of the '29s might be truck? Based on the '31 information from the Engineering Features which gives the 1 1/2 ton truck as 5/16" hex cells versus 3/8" for passenger (and I assume 1/2 ton) measuring the cell size might help ID it.
Others & Dave, Is 3075 different from 3088? Cell size? Width? length? thickness? Possibly 1/2 ton which fits the '31 style radiator shell?
Is the 3092 a '33 commercial radiator? 32 L is in the '33 production time frame.
Posts: 977 Likes: 7
Chipper, the guy I have been exchanging emails with said the date code is 33 K, and the embossed number is 31019, but jiaccino said 31001 and 31002 are 1933 numbers. I assume the K refers to November 1933. Were the 1934 models being produced in November 1933?
Bill Masters
Posts: 980 |
Is the 3092 a '33 commercial radiator? 32 L is in the '33 production time frame. '29 H has a replacement F/S core. The other '29 has a replacement V cell core. '32 L has 5/16" honeycomb cells and is from a 1932 car made in Dec. 1931. I don't know if it's original to the car. '33 F has V cells, I think it has the original core.
