#262096 11/25/12 03:23 PM
In another thread we were talking about the accessory spare tire monitor. It's a hose that attaches to the valve on the spare so that air can be added, or pressure monitored without taking the spare from the trunk. I had stated that the other end of the hose comes out someplace like below the rear bumper, but then found this photo on the Chevybombs website. Is this the correctly installed accessory?
brewster #262099 11/25/12 03:28 PM
I think most folks simply cut a hole in the trunk floor to access the valve stem. On the business coupe anyway. laugh
brewster #262100 11/25/12 03:31 PM
Proper position...But, I've only seen them on the left (driver's) side...I mean...That's where the tire is...Anyway...
Yeah...Haven't seen this accessory for sale on EBay, for a while...Are you looking for one...?
kevin47 #262101 11/25/12 03:33 PM
Didn't they all come with a hole in the trunk floor board...? I know mine did...In 1947...
Remove the tire...? Heck, too avoid having to open the trunk...!
kevin47 #262105 11/25/12 03:46 PM
I thought they all did because mine had one but Steve had to cut one in his.
Tiny #262107 11/25/12 04:21 PM
Not looking for one... Just wanted to correct the error in my post on the other thread. I started a new thread because we got off topic on the old one. The accessory was for '40-'41, so I guess you '37-'38 guys are stuck with your little hole. Kevin is right, it's so you didn't have to open the trunk. Now was it dealer installed? If we were judging at a show, how would we mark the location of the outer end? Would either a lefty or a righty get a deduction, or were dealers sticking them where ever they wanted too?
Tiny #262108 11/25/12 04:22 PM
My 38 coupe does not have the hole cut in the shelf. We talked about this before. They did not come with a hole originally but from what I read some folks complained about having to move the spare tire to air it ..SOOO Chevy made available a drawing template that one could tape on the ledge and know were to cut the hole in with a hole saw. This drawing is pictured on the Old car manuals project web site along with the story .......ED
ED1938 #262109 11/25/12 04:32 PM
My old car didn't have a hole either. I saw Tinys and copied it by guessing the measurements from the rivets in the edgeplate.
[Linked Image from i1302.photobucket.com]
The hole is 2 and 5/8ths diameter.
wawuzit #262190 11/26/12 12:26 PM
This item is something that I find could be very useful on my pickup. How could a guy make one of these? I know you would nee a hose, but what sort of connectors would you need? This would be a very nice feature to have on my 37.
Tech Advisor for 1937-38 Chevrolet Trucks
You can make one quite easily. You would need a fitting from the end of an old tire pump, and a valve stem from a tube, and a short hose. The valve stem would provide the fitting that goes through the back of the tire in the vicinity of the tail light. The other end is screwed onto the valve stem of the spare tire.
Agrin devil
They can also be purchased at almost any R.V. store.... patriot
p.k.
1956 BEL AIR 2 DOOR HARDTOP
