Posts: 140 |
I am trying to identify where these two part are suspose to go. The spring is 6 5/16" long and 3/4" dia. The two buttons are 1 3/8" dia. Tim Beilby http://s1308.beta.photobucket.com/user/beilbyt/library/?
Posts: 3,136 |
Okay, you ready for this...? Muffler Ground Spring...Okay, I know what your thinking...That's what I thought ,too Anyway, it's just a guess...The others look like modern shock washers...Hope that I could help/confuse...
Posts: 4,446 |
Parking brake linkage spring. The washers...no idea.
Posts: 3,136 |
Darn it...! I give up...I'm never right...Maybe I better stick to '47's...
Posts: 1,194 |
Posts: 4,446 |
This is a 3 year old photo of my coupe. It doesn't look anything like this now,but you can see this spring next to the frayed wiring.
Posts: 3,136 |
Okay...Couldn't you get the muffler ground spring in the photo, too...? Oh, wait a second...That "thing's" long gone, huh...?
Posts: 4,446 |
My old exhaust pipe had a welded on attachment for the spring but the spring was gone. I think when the 216 was swapped out for the 235 it never was put back on. I've got a fenton split manifold and all new twin exhaust now. I never fully understood what the spring was for. Some say radio ground and some say swag in the exhaust. Neither one make any sense to me.
Posts: 1,135 |
Looks like the clutch return spring to me..The others are,like someone else said, modern shock absorber washers that go over the rubber bushings....ED
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
I'm with Ed, looks like a clutch pedal return spring to me. The two washers look too small to me to be shock related. The center hole appears to be 1/4".
Posts: 724 |
My guess on the washer type parts would be internal parts for the brake wheel cylinder..Billu38
Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
There are no washers like that in a 38 brake cylinder.
Ed
