Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
Posts: 523 |
goods great mine should be here friday. i won`t be installing it until i pull my 30 off the road for the winter. if somebody who installs thiers soon report on how to works out. please.
Posts: 523 |
if you look on the box it says to reuse the grease cup for looks.
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
The pulley is the give away that it is a re-production. Will the original pulleys fit this pump?
Joined VCCA June 1, 1961
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Is that because of the casting numbers, or some other feature.
JACK
The original pulleys do not have a machined surface on the outside diameter. They have a sand casting surface.
Don't get me wrong. If I needed one I wouldn't think twice about buying one for our car.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Will this also fit 1932?? if not what is the difference between 31 and 32 pumps?
What is the difference in the pulleys?
Posts: 117 |
I ordered one from FS for 1932 WP-837035, (1932-1934). It's currently on back order.
Posts: 584 |
Mine came in the mail today!
Brandon
Youth is wasted on the young
To further explain the differences in the '29-'31 pumps and '32-'34, the fan belt is closer to the radiator in the later pumps. That is due to a thicker harmonic balancer which locates the crankshaft pulley further forward.
Thanks for clearing this up Chipper. I didn't know pulleys were short or tall. Things must be different on the other side of the rockies.
Posts: 584 |
Just to make 100%, absolutely dog-gonned sure.... even though this pump has an alamite in it, I DO NOT have to use it. I don't have to do ANYTHING AT ALL, nothing to this pump. Just install it and say, "Weeeeeeeeeeeeeeeeeeeeeeee," while driving.
Brandon
I believe you got that right. I would buy one for a spare if I didn't have a NOS spare.
Yep, Remember what happened to the original price of the radiators!!!
I bought one for $395. I think they are over $1,100 now.
Posts: 75 |
Is the water pump painted gray or black? What about the pulley?
Chris
Posts: 29 |
Nice, we pre-ordered two. Will be nice to loose the squeaks of the current ones we have and even more so the leaks!
Hope mine are on the way soon :)
These NEW replacement pumps arrive with a nice semi-gloss BLACK finish on them. Get your touchup guns ready. ![[Linked Image from barkerville.net]](http://barkerville.net/webphotos/vccachat/2012/NewWaterPumps.jpg)
Posts: 117 |
So, gray isn't original color? Mine is gray. Do folks just go to Napa or any auto parts store and buy engine paint?
