#256166 09/27/12 03:17 AM
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
New water pumps are now being delivered!!!!
[Linked Image from barkerville.net]
goods great
mine should be here friday.
i won`t be installing it until i pull my 30 off the road for the winter.
if somebody who installs thiers soon report on how to works out. please.
To look authentic for show, the Zerk fitting has got to go.
if you look on the box it says to reuse the grease cup for looks.
Right. That's why I made note that for show the Zerk fitting needs to be removed.
The pulley is the give away that it is a re-production. Will the original pulleys fit this pump?
Joined VCCA June 1, 1961
Is that because of the casting numbers, or some other feature.
JACK
The original pulleys do not have a machined surface on the outside diameter. They have a sand casting surface.
Don't get me wrong. If I needed one I wouldn't think twice about buying one for our car.
Will this also fit 1932?? if not what is the difference between 31 and 32 pumps?
The 1929-32 pumps are the same, however, 1932 uses a different pulley.
What is the difference in the pulleys?
The 1932 pulley is not as tall as the 1930-31 pulley.
I ordered one from FS for 1932 WP-837035, (1932-1934). It's currently on back order.
Mine came in the mail today!
Brandon
Youth is wasted on the young
To further explain the differences in the '29-'31 pumps and '32-'34, the fan belt is closer to the radiator in the later pumps. That is due to a thicker harmonic balancer which locates the crankshaft pulley further forward.
Thanks for clearing this up Chipper. I didn't know pulleys were short or tall. Things must be different on the other side of the rockies.
Just to make 100%, absolutely dog-gonned sure.... even though this pump has an alamite in it, I DO NOT have to use it. I don't have to do ANYTHING AT ALL, nothing to this pump. Just install it and say, "Weeeeeeeeeeeeeeeeeeeeeeee," while driving.
Brandon
I believe you got that right. I would buy one for a spare if I didn't have a NOS spare.
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
Yep, Remember what happened to the original price of the radiators!!!
I bought one for $395. I think they are over $1,100 now.
Is the water pump painted gray or black? What about the pulley?
Chris
The water pump and pulley should be painted engine color, dark blue-gray.
Nice, we pre-ordered two. Will be nice to loose the squeaks of the current ones we have and even more so the leaks!
Hope mine are on the way soon :)
1931 5 passenger 2 door
1932 5 passenger 2 door
1950 3100 Pickup
http://gsbvcca.org/
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
These NEW replacement pumps arrive with a nice semi-gloss BLACK finish on them. Get your touchup guns ready.
So, gray isn't original color? Mine is gray. Do folks just go to Napa or any auto parts store and buy engine paint?
