PHC30 Offline OP
I am would like to get the Vehicle Lubrication Quantities in Gallons or Litres - For the Engine , Transmission & Differential to suit a 1930 Chevrolet Universal Sports Roadster .
It is fitted with a 194 Engine & Three Speed Manual Transmission .
It is not listed in my owners / repair manual .
Thanks for your help .
Paul
AUSTRALIA
Become a Member!
HI Paul,
Engine oil capacity is 4.73 litres
Gearbox capacity is 1.18 litres from dry (600 W oil)
Rear axle capacity is 1.89 Litres.
Cooling system capacity is 10.88 litres (1931 spec.)
Fuel tank capacity 39.74 litres. (1931 spec)
JACK
PHC30 Offline OP
G,Day Jack ,
Thanks for the information
It is greatly appreciated
Regards, Paul
HI Paul ,
i forgot to mention that the rear axle lubricant is recommended to use 600 W as well .
JACK
600 wt. is nothing short of amazing...minor seal leaks ..tranny..rearend..axle seals all stopped on my 32. very happy
PHC30 Offline OP
Jack ,
I have ordered 600w ( Transoil 250 Penrite ) from Autopro and will change both Transmission and Differential .
My Universal Housing has a gease nipple fitted on top , i beleive this is not correct ,it should be a blank plug. Somebody said putting grease in the housing does not really lubricate the joint .
Is this correct ?
Thanks for your help once again.
Rgeards,
Paul
Noosa Heads, QLD. 4567
There should be a plug on the universal joint housing and yes, it is correct that grease should not be used in the housing.
PHC30 Offline OP
1930 Chev Universal Sports Roadster : GM Australia ( RHD )
How do i drain the diff oil , i cannot find the drain plug , do i remove the bottom lowest stud on the differential carrier ( as in later model GM - Holden Salisbury Differentials 1970 - 1982 )or do i remove the backing plate ?
Pls advise , thanks.
Paul
With my 38 the lower diff cover bolt should have drained oil but there was that much crud there I ended up removing the whole cover, some of the crud was rusted roller cages out of the bearings.
PHC30 Offline OP
Tony ,
Thanks , I don't think i have bearing problems, i just need to change the Diff oil so i know where i'm at with the Roadster.
Then i can cruise without problems, thanks again.
Regards ,
Paul
Noosa Heads 4567 QLD
