#221233 10/10/11 12:44 PM
5050 Offline OP
How do you make led turn signal lites flash correctly on a 6 volt battery? grant
1938 master coupe 1966 triumph tr4a vcca 047674
5050 #221235 10/10/11 12:51 PM
With a 6 volt flasher and the proper bulb load which would be two 21 candle power draw bulbs. For later cars it would be 1154 bulbs which are double filament.
5050 #221701 10/15/11 11:02 AM
You can buy flashers made for LEDs at most vendors.
Tiny #228397 12/22/11 07:42 PM
Did you ever work anythig out on this?
I'm looking to add turn signals to our 1931 and 1932 that are both 6volt. I got a turn signal kit for 6v off eBay but I'm wanting to go with an LED based solution. The 1931 has quarter lights and was thinking of useing those for the front signals. On the 32 we don't have those so I'll have to come up with something.
1931 5 passenger 2 door
1932 5 passenger 2 door
1950 3100 Pickup
http://gsbvcca.org/
frosendo #228416 12/22/11 11:14 PM
Quarter lights?? Do you mean cowl lights?
frosendo #238964 04/05/12 04:17 AM
I have a circuit diagram and some suggestions re: LED'S, that I could send to you if you haven't sorted it by now.
Regards,
John.
frosendo #239864 04/14/12 06:19 PM
on my 32 coach i wired the park lamps in the headlight for turn signals with an amber bulb. boy does it show up!
they don't make em like they usedta
So you don't have park lights now?
jayen #239951 04/15/12 01:49 PM
lol
Last edited by kevin47; 04/15/12 01:50 PM. Reason: it's getting dark...gotta go...!
kevin47 #245790 06/15/12 09:38 AM
I want to convert the cowl lights on my 32 to turn signals. I will need a double filament bulb with straight pins to replace the current bulb so I can continue to use them as cowl light as well. Dose anyone know the correct 6V bulb # to do this?
BeachVette #245798 06/15/12 11:36 AM
WAGNER Auto Lamp No. 210, 6V 15 C.P. DC
Joined VCCA June 1, 1961
Back Roads #245806 06/15/12 01:48 PM
The # 210 dose not look like it is a double filament Bulb. I want to retain the use of the cowl lights and use the 2nd filament and the turn signals there for it will need to be a double contact and double filament bulb.
BeachVette #245845 06/15/12 09:31 PM
The only thing you could not do is have your cowl lights on and use your trun signal at the same time. How often do you drive with your cowl lights on and want to use turn signals?
I do not believe in fifty years I have driven with my cowl lights on The only time I ever turn the cowl lights on is for the Field Entrance Check for judging.
Back Roads #245848 06/15/12 10:02 PM
Thats true, I seldom use the cowl lights. I just thought if i could find the correct double filament bulb I could retain them.
BeachVette #245886 06/16/12 06:47 AM
I may have missed something but if you have the cowl light on how would you see the turn signal light when you used them. I know they would be different candle powers. I'm not sure how your turn signal works.
Andys29 #245892 06/16/12 09:05 AM
The cowl lights would only be used for parking
BeachVette #246089 06/18/12 06:34 AM
Thank You. I sure forgot that and now I understand.
Andys29 #246108 06/18/12 08:52 AM
If I have the correct double filament bulb it will work for both turn and cowl lights
BeachVette #246122 06/18/12 10:13 AM
In addition to the double filament bulb you will need to change the socket so it has two separate wires going to it. One for each filament.
Chipper #246139 06/18/12 12:54 PM
I have the correct socket just need a good bulb number
BeachVette #246145 06/18/12 01:34 PM
1154 ?????
devil Agrin
BeachVette #246146 06/18/12 01:37 PM
1002 or 1158 or 1188 look like they'll fit. <click>
Tiny #246160 06/18/12 04:29 PM
I like the 1158 in that the socket can be retained and the pigtail would be the only item to replace. Then you must test which of the two ways of installation is the correct one.
devil Agrin
