To be clear Al, a different badge was used with the stoneguard than the badge used on the rad shell. As indicated above, the proper one for the stone guard had a press in clip on the lower half of the back of the emblem (rather than centered in the emblem as for rad shell)which fit snugly into the hole in the stoneguard. Since most original badges have this part rusty, the clip will not likely hold very securely, which is why some suggest using 3M tape to hold it in place. Also you can use an original rad shell badge by simply filing off the old clip and using 3M. That is what I am using, holds great, and can be peeled off with care.
