Posts: 104 |
Has any one converted there ignition to 6v electronic? How did it work? Who sells the conversions? I've seen some by pertronics but not sure about fit.
I have a 6 volt electronic on my '28 Coupe. It was the first made for a Chevrolet by First Street Ignitions http://www.fsignitions.com/ . So far it has been trouble free but I take a spare point ignition distributor to switch out in case there is a problem on the road. I can't fix the electronic one if it fails but I can get the point ignition fixed well enough to get home.
Posts: 104 |
Thanks Chipper I will check them out
Posts: 65 |
Go on ebay, find distributors,in auto parts look for heidizzy. He makes custom HEI Distributors. He only sells on ebay. I had one made a year ago, and it has been perfect. I paid about $250.00 and it is so easy to install. The unit is a one wire hook up
Buckeye
Posts: 65 |
I went on ebay and could not find heidizzy, he must not be on ebay anymore. Sorry
Buckeye
Posts: 77 |
try - /www.ebay.com/itm/HEI-CHEVY-STRAIGHT-6-1929-1934-GM-DISTRIBUTOR-6-VOLT-/370218565566?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item5632beffbe
on ebay Regards, John
Posts: 104 |
I've seen those on eBay wasn't sure if they were truly a fit for the 194 engine. I will check it out too.
Posts: 65 |
The part #370218565566 is the same one I installed a year ago. It is custom made to fit the 32 chev. Best thing that I ever did for my baby. I can set the timing at 20 degrees and it runs great and has more power.
buckeye
Posts: 104 |
Does it come complete with gear and ready to run?
Posts: 77 |
Does it look like the original?
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
JACK
Mychevy, yes they come with the drive gear and ready to run.
I emailed the seller / manufacturer and he says he assembles them for the vehicle that they will be used in when you order. 12 volt or six volt, male oil pump drive tang or female drive tang.
JACK
Posts: 65 |
The cap is much larger than the original, but it all fits. The coil is built in and you only have one wire to hook up. You will need to know if the end of your shaft is male or female. My 32 has the recessed female end. You will also need to replace your sparkplug wires, the old ones will not take the higher voltage. Napa stocks the hige voltage wires that fit your car. buckeye
