Posts: 387 |
I need to repair the hear riser in the exhaust of my 33 Chevy Master. Anyone know where I can find these parts?. If you would have a order number, that would be of great help. Don
The best bet is to make them yourself. Find a stainless shaft and make a plate from sheet metal. Put them together.
Posts: 387 |
Chipper, That sounds like a possible to do. However I have no idea what the spring layout and adjustment is. Can you help? Don The 33 engineering Manual that I've seen on line shows the parts of the heat riser. However the picture is very poor. Does anyone have a better image of these parts that they are willing to share? Don
Posts: 387 |
The Member's Photos are a great help. Thanks Don
Posts: 598 |
Don: I just sent you a number of photos to your listed email address rather than tie up memory here. Hope they help. Richard
Posts: 387 |
Richard, the photos are great! My local machine shop encouraged me to be lazy today. They machined, drilled, threaded, all the parts for the hear riser for $25. And I got it back in 3 hours. It made my afternoon. There are some special advantages to living in a smell town. Don If you ever get stuck in Northern CA and need machine work, let me know. Also your manifold is beautiful.
Posts: 598 |
Posts: 387 |
I need the small cover part that fits on the outside of the exhaust manifold and surrounds the spring. It can be seen in this photo. https://vccachat.org/ubbthreads.php/galleries/235608Can anyone help? Don
Posts: 173 |
Hi Don. I am about to do up my 34 manifold heat flap and would appreciate if you would kindly email me the photo on the manifold.do you know if the Bimetal spring is available to purchase anywhere.
I HAVE TRIED TO VIEW THE MEMBER'S PHOTOS BUT FOR SOME REASON I AM DENIED ENTRY I WILL NEAD TO CONTACT VCCA TO RECTIFY THE PROBLEM.
Cheers Paul Mitchell. Email pm.exports@xtra.co.nz
Hi Paul, In order to post pictures and other functions on the Forum you must be a member of the VCCA. If you need help to join, just let us know and someone will assist you.
Posts: 387 |
Does anyone know where I can get the by-metal spring and cover for the hear riser? Don
Posts: 387 |
I have found a heat riser spring for a 55 Chevy. Any thoughts on how close to the one I need this spring might be? Don
Posts: 387 |
1937 heat riser spring seems to look the same. Filling Station part.
Posts: 173 |
Hi Ray. I am a member or the VCCA but for what ever reasons if I try to open any of the VCCA member's photos I am denied entry. I will try to work it out today thanks for you help. Cheers Paul.
Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
Paul... You made it a callenge. I finally found your membership record and I've added your VCCA number to your Chat profile. Also modified your permissions so you have full access to the other Member Forums. By the way, if any other members are reading this and don't seem to have full access, please read the instructions on the Hompage https://vccachat.org/ where it says: VCCA MEMBERS: Get access to additional forums, and post photos Find out how Click HERE
Bill Barker Previous VCCA CHAT Administrator (VCCA Member: 9802)
Posts: 387 |
This is the heat riser spring that I need. Don ![[Linked Image from vccachat.org]](https://vccachat.org/gallery/default/medium/1965.jpg)
Posts: 173 |
Hi Bill. Thank you for you efforts. Its good to be able to view all the site, the strange thing I was able to entry some areas but not all. Anyway thanks to you, all is working well. Cheers Paul.
Posts: 387 |
Still looking for input on where I might find the heat riser spring. Don
Posts: 408 Likes: 10
Posts: 408 Likes: 10 |
I realize this is an old thread but I also need to replace the thermostatic coil spring for the heat riser on my 34 Master. The original one, which is broken, has a few more coils than those currently available. Does anyone know where I can get an original one or will the current replacements for 1937 and newer work?
Posts: 73 |
Brendan,
The 1933-1936 models used part number 837491. I cannot see where it ever crossed. Some years back I purchased 838573 from a Chev. dealership and it has worked really well on my 1933 Master model. I don't remember if they told me it was a cross or not. The 1937-40 part number was 838561 which later crossed to the 878573 so the 1937 replacements should work OK.
Thank you for the information. I was able to bend a new tab in the center coil of my original spring and reinstall it. I tested it with a propane torch a couple times and it worked fine. I intend to keep an eye on it in case breaks (and it probably will) again. In the mean time, I intend to order a later replacement and have it on hand.
