Posts: 42 |
Good Morning, I bought a new wiring harness for my 32 1/2 ton and am setting it up on the bench before I install it. Should I have continuity through the housing of the fuel gauge? Thank you Ed
32 1/2 ton panel delivery 55 Cameo And a Plymouth
Are you talking about the gauge on the dash? Yes. If you are talking about the sending unit yes, about 0-30 ohms as you move the arm.
Posts: 42 |
I am talking about the dash gauge. There seems to be continuity between the terminals and the case. I would hate to hook it up and let the smoke out.
Posts: 42 |
Hooked it up to battery power..........No Smoke
Thank you Ed
Posts: 230 |
On a different leg of this question, where did you purchase the wiring harness and are you pleased with what you received? I am ready to purchase one for my 29 and am looking. Thanks.
Erik Langhofer Phoenix, Az.
Posts: 42 |
I bought the harness from YnZs Yesterdays Parts. I am very happy with it. It seems to be made very close to the original. The only thing is I have a truck and they ran the fuel gauge wire all the way back. My tank is under the seat. No problem, just cut to fit. Ed
