Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
1928 steering box lubricant #232481
01/28/12 11:22 PM
01/28/12 11:22 PM
new zealand
D
dixies Offline OP
dixies  Offline OP
D
new zealand
Hi could some one tell me what is the correct lubricant I should be using in my 28 chev steering box and what amount
Cheers
John Dix
dixies
The Filling Station 1912-28
Re: 1928 steering box lubricant [Re: dixies] #232486
01/28/12 11:58 PM
01/28/12 11:58 PM
Vancouver, WA
AntiqueMechanic Offline
ChatMaster - 9,000
Vancouver, WA
Hi John, and welcome to the Chevy Chat II. You have come to the right place for assistance on your 1928.
The correct lubrication for the steering box is 600 weight oil. However, if worn, it will run out fairly quickly. So, I would mix some of the 600 with some light grease and put that in the box. It may still leak, but not as bad.
devil Agrin
Member Chat Group - Non-Geographical Region
Re: 1928 steering box lubricant [Re: AntiqueMechanic] #232489
01/29/12 12:07 AM
01/29/12 12:07 AM
Melbourne, Victoria, Australia
1928isgreat Offline
1928isgreat  Offline
Hi John,
As Antique Mechanic says, you have come to the right place.
I have had great success with a Penrite product, made especially for Vintage Steering boxes. It clings to the parts and has anti leak qualities. I also use it in my Uni Joint.
Details are
http://www.penriteoil.com.au/products/vintage,-veteran-&-classic/steering_box_lubricant
http://www.penriteoil.com.au/pis_pdfs/0STEERING%20BOX%20LUBE%20OCT%202011.pdf
Let us know how you get on.
Cheers
Ray
Re: 1928 steering box lubricant [Re: dixies] #232512
01/29/12 01:29 AM
01/29/12 01:29 AM
new zealand
D
dixies Offline OP
dixies  Offline OP
D
new zealand
Hi there Chaps,
i have put Penrite transoil 140 in diff
and gear box, how much do I but in the steering box
Cheers
John Dix
dixies
Re: 1928 steering box lubricant [Re: dixies] #232522
01/29/12 01:54 AM
01/29/12 01:54 AM
N.S.W.,Australia.
CJP'S 29 Offline
CJP'S 29  Offline
N.S.W.,Australia.
As the Penrite steering box lube is a very thick semi-fluid grease,you could try putting some in an oil gun(similar to a grease gun,but designed for thick oils),or put a small amount into a plastic bottle,microwave it for 30 seconds at a time til it's fairly fluid and easy to pour,then fill the steering box up to the bottom of the grease nipple hole.
This the best way I've found to do the steering boxes in my '28 truck & my '29 Olds.
idea
CJP'S 29
Re: 1928 steering box lubricant [Re: dixies] #232527
01/29/12 02:06 AM
01/29/12 02:06 AM
new zealand
D
dixies Offline OP
dixies  Offline OP
D
new zealand
thanks chaps,
I shall have a talk to
my penrite agent and get some of there steering box lube
cheers
john dix
dixies
Re: 1928 steering box lubricant [Re: dixies] #232528
01/29/12 02:35 AM
01/29/12 02:35 AM
Perth Western Australia
S
Steelin_Time Offline
S
To get the oil into the steering box I use an almenite grease fitting and original grease gun.
Re: 1928 steering box lubricant [Re: Steelin_Time] #232529
01/29/12 02:40 AM
01/29/12 02:40 AM
1928isgreat Offline
1928isgreat  Offline
I use the same procedure as Steelin Time
I use a grease gun with the Penrite steering box lube, as the tube fits inside a modern grease gun, and I apply through the grease nipple.
Cheers
Ray
Re: 1928 steering box lubricant [Re: 1928isgreat] #232558
01/29/12 01:55 PM
01/29/12 01:55 PM
The Great State of TEXAS
Chipper Online happy
Chipper  Online Happy
Because of the high viscosity and small passage to add lube taking it slowly is a good idea. It allows air to escape and time for the lube to settle.
Re: 1928 steering box lubricant [Re: Chipper] #232614
01/29/12 11:14 PM
01/29/12 11:14 PM
Sydney, Australia
C
chevguroo Offline
chevguroo  Offline
C
Sydney, Australia
I've done this with my grease gun and use the Penrite grease. When a used my grease gun it tended to leak around the grease nipple so I now get a lenght of 1/4" clear plastic hose which fits nicely into the hole once the the grease nipple is removed. I suck the Penrite oil about 2 feet up the tube then blow it in. This also fits under the front seat better than a gease gun.
Chris
Moderated by  AntiqueMechanic
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
2 registered members (Floats, 1 invisible), 6 guests, and 5 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
Truck1927
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
FB_Tweed, Dones475, aland, Stickdude, Achipmunk
15124 Registered Users
Forum Statistics
Forums69
Topics49,997
Posts362,518
Members15,124
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
