Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
Front leaf spring shackle #231991
01/24/12 06:30 PM
01/24/12 06:30 PM
sweden
olleschevy Offline OP
sweden
Hi. I am just about to reassemble the front leaf springs after some refreching. I bought the new replacement shackles from Gary Wallace.
Does anyone know what torque to use on the nut? There are two spring washers in the kit. Use one or both as a pair?
Olle
The Filling Station 1929-32
Re: Front leaf spring shackle [Re: olleschevy] #232019
01/25/12 12:32 AM
01/25/12 12:32 AM
The Great State of TEXAS
Chipper Offline
Chipper  Offline
If you have the repair manual it shows the tool to set the shackle nuts. It shows a measuring device that I have never seen. So I just set them so there is enough pressure to keep the shackle sides snug but not tight on the pins.
Re: Front leaf spring shackle [Re: olleschevy] #232022
01/25/12 12:40 AM
01/25/12 12:40 AM
Cleves, Ohio
DanR Offline
DanR  Offline
Cleves, Ohio
Hi Olle,
Since you are a VCCA member, look at page 38 of the November, 2011 G&D. Steve Kassis gives a good description of replacing spring shackles. His recommendation is to adjust the spring washer to a clearance of .010".
Happy Motoring,
Dan
Re: Front leaf spring shackle [Re: olleschevy] #232043
01/25/12 02:37 AM
01/25/12 02:37 AM
Nova Scotia, Canada
Gunsmoke Offline
Gunsmoke  Offline
Nova Scotia, Canada
I understand they used a single washer on the front shackles and a double on the rear shackles. I just replaced all my shackle pins and snugged the shackle bolts to the point about 1/2 the curvature of the washer was flattened and stopped at that. Depending on stiffness of washers, that should do. Don't forget to install the nut locks.
Re: Front leaf spring shackle [Re: Gunsmoke] #232051
01/25/12 04:18 AM
01/25/12 04:18 AM
Eagle Point, Oregon
Junkyard Dog Offline
Eagle Point, Oregon
Gunsmoke's description and procedure are correct.
Re: Front leaf spring shackle [Re: olleschevy] #232062
01/25/12 09:39 AM
01/25/12 09:39 AM
sweden
sweden
Thanks guys. Just rembered seeing it in G&D.
Olle
Moderated by  32confederate, d2d2
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
0 registered members (), 1 guest and 4 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
Truck1927
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
FB_Tweed, Dones475, aland, Stickdude, Achipmunk
15124 Registered Users
Forum Statistics
Forums69
Topics49,997
Posts362,511
Members15,124
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
