Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
1928 Chev 4 Distributor Part 635B #231112
01/17/12 12:00 AM
01/17/12 12:00 AM
Melbourne, Victoria, Australia
1928isgreat Offline OP
Hi Guys,
I have several of these, and some have up and down movement in the main shaft between the top of the drive gear and the bottom of the housing, others very little. I recently purchased a NOS unit that has about a washer thickness of up and down movement. In the past I have taken this movement out, but I am now thinking it should be there.
Anyone have an idea as to what it should be?
Cheers
Ray
Vintage Auto Garage - 6 Volt
Re: 1928 Chev 4 Distributor Part 635B [Re: 1928isgreat] #231114
01/17/12 12:22 AM
01/17/12 12:22 AM
Eagle Point, Oregon
Junkyard Dog Offline
Eagle Point, Oregon
That movement should be there.
There is an oil pump thrust washer that sits on top of the oil pump. The washer is approx. .075" thick and this thrust washer causes the distributor main shaft and weight plate to move up in the distributor housing when the distributor is installed. This is done so the weight plate inside of the distributor is not turning on the distributor housing thus causing excessive wear to the inside of the distributor housing.
Moderated by  AntiqueMechanic
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
3 registered members (nhinchas, Rustoholic, pushrod), 7 guests, and 4 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
Truck1927
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
FB_Tweed, Dones475, aland, Stickdude, Achipmunk
15124 Registered Users
Forum Statistics
Forums69
Topics49,997
Posts362,518
Members15,124
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
