Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
1937 Chevy 1/2 ton pickup gas tank #231050
01/16/12 03:57 AM
01/16/12 03:57 AM
Texas
3
37chevyPU Offline OP
Texas
I am starting to restore my dad’s 1937 Chevy ½ ton pickup. I believe that the gas tank is in good condition, but I am not sure that I want to sit on a working gas tank. My plans are to remove and restore the gas tank if it is possible and put in back under the seat - I will add a working gas tank under the bed. My question is “how do I remove the original tank under the seat”? I know that there are two bands securing it – are they bolted somehow and how do I remove the bands to remove the tank? Thanks for your comments.
Re: 1937 Chevy 1/2 ton pickup gas tank [Re: 37chevyPU] #231060
01/16/12 07:52 AM
01/16/12 07:52 AM
Goulburn Australia
tonyw Offline
tonyw  Offline
Goulburn Australia
I suspect your tank is the same as my Holden bodied 38 and yes there are bolts on the strap ends that undo from under the floor. They are generally well rusted and break off when you try undoing them. Use lots of wd40 and sometimes a little heat helps, if you use heat after wd40 check for combustible material above the floor and wrap the strap end with a wet rag while heating under the floor.
Re: 1937 Chevy 1/2 ton pickup gas tank [Re: tonyw] #231072
01/16/12 02:09 PM
01/16/12 02:09 PM
Texas
3
Texas
Thanks, I will give it a try.
Re: 1937 Chevy 1/2 ton pickup gas tank [Re: 37chevyPU] #231077
01/16/12 03:10 PM
01/16/12 03:10 PM
USA
3
37Blue Offline
37Blue  Offline
USA
Tony is correct, the '37 gas tank is bolted as described. There is a drain valve and short hose on the bottom right side, under the cab. If the hose is still there it will need to be removed as well.
Re: 1937 Chevy 1/2 ton pickup gas tank [Re: 37Blue] #231084
01/16/12 04:39 PM
01/16/12 04:39 PM
Texas
3
Texas
Thanks all, I was able to remove the tank - twisted off three of the four nuts. Some rust on the outside, but hopefully it is usable (although I don't plan on using it as the working tank}. I will try and restore it and leave it under the seats for support and originality. There is moisture in the tank,it is possible that some water made its way in when I hosed down the inside of the cab a few months ago.
Terry
Moderated by  37Blue
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
0 registered members (), 1 guest and 4 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
Truck1927
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
FB_Tweed, Dones475, aland, Stickdude, Achipmunk
15124 Registered Users
Forum Statistics
Forums69
Topics49,997
Posts362,511
Members15,124
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
