#230132 01/09/12 03:21 PM
61 vert Offline OP
Where is the VIN plate located on the 40 to 42 convertible?
61 vert #230137 01/09/12 04:18 PM
Passenger side door floor pan on the side pan is here my plate is located. You will have to pull back the floor liner to access the plate as it is rivited on. Should be the same for the convertible. stressed dance
Ken's 1940 Special Deluxe Sedan
1970 Cadillac Hearse
61 vert #230141 01/09/12 04:32 PM
If you're trying to verify the title "VIN" number of the car, be aware than many states used the engine number for that purpose through the mid '50s. If that is the case on your car the unit serial number on the data plate won't match your title.
Tiny #230155 01/09/12 05:47 PM
1941-42 did not have a VIN #. The serial # was located on the data plate on the floor on the right side of the car.
devil Agrin
61 vert Offline OP
Found it on the 40 and the 41, but not there on the 42. Was 42 supposed to be in the same place?
Instead of working on old cars they got me cking VINs against the master list. So far I have found 13 VINs here of by one digit. Need to see if the titles are also off or if we need a new typist in the office.
61 vert #230165 01/09/12 06:15 PM
VIN number is the term used by most people and even some states to refer to all vehicle serial numbers. To be completely correct the VIN number is a Federally mandated number containing 17 characters (numbers and letters). VIN numbers started in 1981. Altering a VIN is a Federal offense.
Any vehicle number prior to 1981 was a vehicle or car or truck "serial" number. Those numbers were placed on a given vehicle by the manufacturer using their own system or code(s).
Chipper #230168 01/09/12 06:28 PM
61 vert Offline OP
Thanks for the help, still haven't located the 42 "serial" number. Can't find it on a 28 tourer either. Assume it should be tacked to the seat base on the passenger side.
61 vert #230171 01/09/12 06:34 PM
The '42 had it in the same place. In 1946 it was moved to the right front door hinge pillar.
61 vert #230174 01/09/12 06:36 PM
Should be on the seat riser but may be on the passenger side main sill or even on the drivers side sill as repairs or restoration may have caused it to move or be lost.
Chipper #230188 01/09/12 07:01 PM
61 vert Offline OP
Thanks guys. I'll keep looking.
61 vert #230273 01/10/12 08:52 AM
Under the hood on the firewall on Canadian cars, which also quote the engine number, trim, paint and body serial number!
