JoeS Offline OP
The shaft that sticks out the side of the transmission that the shift linkage clamps onto has a key/key-way in it. My "key" fell apart when I was disassembling it. Does anyone know the name of this key, and where I can get one?
Thanks.
Joe
JoeS Offline OP
No, not specifically.
I've been reading the shop manual. The piece that clamps around the gear shift lever is called the "reactionary lever" and it's all located under the "metal boot".
The picture you referenced does show the lever and the boot on the right.
The "reactionary lever" is 4.041, on this page, and would be what surrounds the shaft/key.
http://chevy.oldcarmanualproject.com/parts/1929_41/41cp089.html
JoeS Offline OP
You're right. It doesn't mention anything about a key. Perhaps I need to take another look.
JoeS Offline OP
Mystery solved. The "key" is actualy part of the lever. The broken piece I found on the floor broke off the lever.
[img:left][Linked Image from vccachat.org][/img]
{img:left][Linked Image from vccachat.org][/img]
BINGO !!! Glad you have all the parts needed. Good Luck.
auto
So Joe, you did not break anything, the piece just fell on the floor? Am I correct to assume you do not need this part? Thanks, Mike
JoeS Offline OP
The piece I found on the floor did break off of the lever, but it was only a small piece and I'm sure I can get buy fine with what is left.
