Posts: 42 |
i recently picked up an original electrolock for my 30 and it appears to work good. i am curious as to how it mounts to the distributer the end of it only has the stud sticking out.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
There should be a sleeve on the distributor end of the electrolock. the sleeve is slid off to enable the condensor lead to be fitted in the slot.There is then a spring washer. The threaded stud end goes through a hole in the side of the distributor, through an insulator bush. The inside of the distributor should have a thin sheet insulator between the distributor body and the points spring. The stud passes through both of these, and then has a a small curved plate and a nut on the end.
JACK
Posts: 220 |
Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
CCII is Chevy Chatter II --- This Chat Forum.
"It's wise to choose a SIX"
Posts: 345 |
Mike, I e-mailed you several photos that show how the electrolock mounts to the distributor. Frank
