#226998 12/08/11 01:14 AM
i recently picked up an original electrolock for my 30 and it appears to work good. i am curious as to how it mounts to the distributer the end of it only has the stud sticking out.
There should be a sleeve on the distributor end of the electrolock. the sleeve is slid off to enable the condensor lead to be fitted in the slot.There is then a spring washer. The threaded stud end goes through a hole in the side of the distributor, through an insulator bush. The inside of the distributor should have a thin sheet insulator between the distributor body and the points spring. The stud passes through both of these, and then has a a small curved plate and a nut on the end.
JACK
There many discussions on CC II regarding how to connect the electrolock to the distributor so you might want to do a search on CC II to review all of that information.
What is CCII?
CCII is Chevy Chatter II --- This Chat Forum.
"It's wise to choose a SIX"
Mike,
I e-mailed you several photos that show how the electrolock mounts to the distributor.
Frank
The 1929-32 Chevrolet parts book has a great illustration of all of the individual electrolock parts for attaching the electrolock to the distributor.
