Posts: 28 |
I have been sent two different sun visors which have been represented as original for my 1930 Chevy Sedan. One has a ridge on the outside and the other is flat with no ridge. I have looked at several pictures but have been unable to ascertain which is the correct visor. It looks like the one with the ridge may be from a 1929 and the flat one from a 1930. Can anyone confirm?
Posts: 28 |
Thank you for the clarification. Do you know what year the ridged model was used? It would be helpful to know.
Posts: 1,966 |
My '31 has a bead molded in around top and bottom edges and coming together at sides of visor.
Posts: 28 |
