I have been sent two different sun visors which have been represented as original for my 1930 Chevy Sedan. One has a ridge on the outside and the other is flat with no ridge. I have looked at several pictures but have been unable to ascertain which is the correct visor. It looks like the one with the ridge may be from a 1929 and the flat one from a 1930. Can anyone confirm?
The outside sunvisor for 1930 was smooth....no ridge was used.
Thank you for the clarification. Do you know what year the ridged model was used? It would be helpful to know.
I would have to see it.
My '31 has a bead molded in around top and bottom edges and coming together at sides of visor.
Thank you that helps.
