Posts: 956 |
Looking for a small decorative shield, that attaches to the front of a winged radiator cap. It's slightly larger than a quarter and will have 2 or 3 small mounting holes. They are likely nickel plated brass. Here's an example. Email me if you have one to sell. Roger
Posts: 956 |
Anyone have one of these, or one similar they would like to sell? Does anyone know any history about these moto-meter shields? Roger
Posts: 802 |
It looks like one that came with the "Arrowmeter" made by Bushnel. I have seen several types of the shield, mostly ones that have a letter monogram. The shield was mounted on a set of wings that also was the cap. Arrowmeters are fairly hard to find, but were high quality usually made from nickel plated brass.
28 Chevy LO Capitol 1 ton, 28 National 2 dr coach, 71 Chevy Custom Camper 3/4 ton. Also 23 Oldsmobile Economy truck and a 24 Olds sport touring.
I have several of the shields, and most of them are letters. As I understand it, you walked in to the parts man and purchased the fancy radiator cap. The parts man pulls out a tray with all the letters of the alphabet and you select a letter that matches your first letter in your last name to put on the cap.
Posts: 182 |
This seller on ebay has a few motometer bits, the link below is for a shield from a motometer; Ebay link
Andrew
While the rest of the crew may be in the same predicament, it's almost always the pilot's job to arrive at the crash site first.
Posts: 956 |
Thanks Bob, Mine has no mfg. mark, but is a winged flip down plated brass one.
Thanks Andrew, That guy has a lotta stuff, I think maybe a part for every car made.
Thanks Ray, I figured you for having some of these. Look to see if you have a K.
Roger
Posts: 802 |
I just took a quick look at mine now that I am home. My Arrowmeter has only 2 holes for the screws in the shield.. It does have a flip down locking tab partly behind the shield so you can tip back the meter part and fill the radiator. Arrowmeters don't have a thermometer, they use a bi-metal strip which causes an arrow or needle to point at the temps marked on the face.
Posts: 956 |
Mine also only has two holes, that must be for a smaller shield, but could easily be drilled for a bigger shield. The third hole could be filled with a cut off screw head, as the locking screw is hidden behind the shield at the bottom location. The wings I have accepts the standard reproduction moto-meters. Roger
Posts: 802 |
Those wings are just like on my Arrowmeter, latch part and all. almost every Arrowmeter I have ever seen has those wings. That is why I think they were made by Bushnel as well. Bushnel is the same company who makes binoculars and optical lenses to this day.
