#202513 04/01/11 06:21 PM
stanman Offline OP
Hi
The book says the small screw head on dist housing represents #1 piston,
then #2 clockwise from there Correct?
There are two screws for the clips ,one for he condenser,the 3rd one is
overthe delco plate. I assume that is the one.
not sure ,
Thanks Stan
earlychevguy
stanman #202527 04/01/11 10:02 PM
I use the terminal closest to the tab on the cap. Or the depression in the top of the distributor. It is also closest to the middle screw (one without spring).
stanman #202530 04/01/11 10:10 PM
Firing order is 1,5, 3, 6, 2 & 4, clockwise on cap.
I always remembered this way, 15 she's too young, 36 she's too old and 24 she's just right!
badboy #203028 04/06/11 11:41 PM
HA Ha, That wouldn't work for me. I'd have to go 153 she's too old, 62 she's just right 4 me! Agrin
Ed
Ed_Osier #203035 04/07/11 01:24 AM
stanman Offline OP
Chipper .. when you refer to the small screw in the dist body, is
it the one directly above the "delco remy face plate?
I'm still unclear where #1 is on my distributer cap.
earlychevguy
stanman #203038 04/07/11 02:12 AM
The number one spark plug wire is located in about the 6:00 position on the distributor cap.
There are only three screws on the distributor body...two with spring clips for the cap and one without a spring clip. That is the screw located above the "Delco-Remy" name plate.
stanman Offline OP
Thanks....
This is one of those things that I need to "get right". Now I think I get it.
Stan
earlychevguy
