#195491 01/18/11 05:03 PM
Is the steering wheel for 34-37 car and 34-37 truck 1/2 ton or 3/4 ton the same thank you
My parts book says 29-37 All (exc.CC,CD, EC,FC). I do not believe the 29-30 wheel is the same. Are you looking for a wheel? If so what year?
My 29-32 book says 31 & 32 are the same so I would think 31 - 37 is probably correct.
Joined VCCA June 1, 1961
The 1929-30 steering wheel is not the same. It is a four spoke wheel with a wood rim. The 1931 and up wheel was used as a replacement on the 1929-30 models by the dealer after the supply of the 1929-30 wood wheels was depleted. Therefore, the later parts books reflect the 1931 and up steering wheel as fitting the 1929-30 models.
Yes the '31 - '37 is the same steering wheel except for the '33-36 Standard. Beginning in 1938 a splined shaft and wheel were installed.
Chipper #195558 01/19/11 08:15 AM
If anyone is looking for a very nice N.O.S. '31 - '37 steering wheel I have one I will sell.
The 1937 Steering wheel for passenger cars is different in that it is narrower in the spokes and the circumference of the wheel has a narrower grip. The 37 truck steering wheels are the same as the earlier vehicles.
Walt D
1934 Mstr 4 dr/sidemnts
1937 1/2 ton P/U
1953 Bel Air HT
1946 Aeronca 7-AC Champ
Walt D #195604 01/19/11 06:27 PM
The 1931-1937 steering wheels are the same - except for the 1933-1936 Standards and the 1937 Master Deluxe. The 1937 M.D. wheel is thinner as mentioned above and each spoke has a thin chrome strip on it.
