I have a 71 Custom Camper 3/4 ton with 350 4bbl AT and factory A/C (which works). It has hot running problems on the highway at speeds over 50 mph when pulling the trailer. God forbid I turn on the A/C. The engine is a crate motor put in in 78 and it also has a newer radiator that was in it when I got the truck that is a 3 row. Did a truck like this come with a 4 row originally? It does have 4 row mounting pads.
28 Chevy LO Capitol 1 ton, 28 National 2 dr coach, 71 Chevy Custom Camper 3/4 ton. Also 23 Oldsmobile Economy truck and a 24 Olds sport touring.
how hot is hot?
Chevrolet
Valve In Head, Ahead In Value
Hot to pike the gauge with several sending units.
have you confirmed the temp with a secondary method? like a hand held IR sensor? I ask because I've had customers chase an overheating problem when it was a sender, wiring, or gauge problem. Better to eliminate them first thing. with the temp gauge pegged it should be blowing coolant out the overflow
a 3 row with a high fin count will cool as well as a 4 row with a low fin count
what type of fan are you running? some fan designs can impede air flow thru the radiator at highway speeds
Chevrolet
I have a 1/2 ton, '71 GMC with 350 V8, std. 3 speed trans, and factory air. It has a very thick radiator, I don't know how many rows of tubes, but it's massive compared to non air trucks of the same age.
I fixed the hot problem! It was the radiator being too small. It made the water go too fast through the core and not let it cool enough. A new 4 row Heavy Duty radiator and it was smooth sailing with no vapor locking, no gauge spiking over 50mph. I could even run the A/C while towing the trailer (with the 23 Olds wooden cab truck on it, it's like pulling a parachute and a crate full of anvils), on a hot 90 deg afternoon and never got past halfway while idling at a long construction site flagman area. Most driving and it was down towards the low temp area. Happy days!!!!
there is no greater satisfaction than the satisfaction of a job well done
beermugs
Chevrolet
The water can't go thru too fast, The problem not enough water was going thru. Its actually going thru faster now because there is less restriction.....but 25% more is going thru.
