#177936 07/14/10 10:56 PM
pe1932c Offline OP
the bottom of my transmission (1932)has a small threaded hole in the plate. Should it be there? Any special bolt? Thanks
paul orednick
305 canal st
lemont Il
60439
Can you post a picture of the hole your talking about? They are two drain holes, one for trans and the other for freewheeling.
32 Confederate
Bruce S. DeFord
VCCA Judging Committee Chair
What type of "plate" are you referring to?
pe1932c Offline OP
It is in the middle of the transmission plate and the hole is about 1/4". I also notice a small leak from the gasket so I will be removing the plate to replace the gasket.
I will be out of town for a month-will continue this then. Thank you.
paul orednick
305 canal st
lemont Il
60439
Please define "transmission plate". Do you mean the transmission cover?
would this be a 4 speed, the power take off cover????
Chevrolet
Valve In Head, Ahead In Value
It sounds like it could be a power take off cover, however, I think that Paul has a 1932 coupe. Actually, it would help if Paul could be more specific when asking questions so that we can provide the right answer to the question.
OK, here is a picture of the bottom side of a 32 transmission. So which hole are you talking about and where is the plate your talking about?
[Linked Image from pacifier.com]
32 Confederate
Bruce S. DeFord
pe1932c Offline OP
I have taken a photo of the hole. I have it and can attach the photo to an e-mail, but I cant get it attached to this Post. (first timer). Can you give me the secret?
paul orednick
305 canal st
lemont Il
60439
Can you be more specific as to where the hole is actually located?
Paul, do you have some place to post the picture on the Web? Otherwise you will need to post it unsder the Member's Photo area.
It you can post it to the web, find the www...... link and in your post find the icon above which shows enter and image.
Let me know if you need more.
32 Confederate
Bruce S. DeFord
pe1932c Offline OP
Please except my THANK YOU! You all tried to help me but I was wrong in my description etc. I now understand that the plate/hole I was referring to was the plate just forward (towards the engine). I believe that the whole there is correct. The trans oil coming out that hole is draining from my trans---PROBLEM! looks like I must pull the trans and reseal!
Any other suggestions?
paul orednick
305 canal st
lemont Il
60439
OK, it sounds like your talking about the Flywheel bottom cover which has a hole in the bottom.
So most likely your cluster shaft is leaking or your front bearing is leaking. Take the transmission apart and use gas tank sealer when installing the lower shaft. Put it around the hole before you slide the shaft in and then coat the outside when finished.
As to the bearing, get a sealed bearing and remove the inside seal and keep the out seal. This way you can get oil to the bearing from the transmission.
You can PM if you want more details.
32 Confederate
Bruce S. DeFord
Are you talking about the flywheel cover below the flywheel? If so, that is not a plate, that is a sheet metal cover. Please be more specific.
