Posts: 110 |
the bottom of my transmission (1932)has a small threaded hole in the plate. Should it be there? Any special bolt? Thanks
paul orednick 305 canal st lemont Il 60439
Posts: 1,919 |
Can you post a picture of the hole your talking about? They are two drain holes, one for trans and the other for freewheeling.
Posts: 110 |
It is in the middle of the transmission plate and the hole is about 1/4". I also notice a small leak from the gasket so I will be removing the plate to replace the gasket. I will be out of town for a month-will continue this then. Thank you.
Posts: 731 |
would this be a 4 speed, the power take off cover????
Chevrolet
Valve In Head, Ahead In Value
Posts: 1,919 |
OK, here is a picture of the bottom side of a 32 transmission. So which hole are you talking about and where is the plate your talking about? ![[Linked Image from pacifier.com]](http://www.pacifier.com/~bruced/images/DSC04719.JPG)
Posts: 110 |
I have taken a photo of the hole. I have it and can attach the photo to an e-mail, but I cant get it attached to this Post. (first timer). Can you give me the secret?
Posts: 1,919 |
Paul, do you have some place to post the picture on the Web? Otherwise you will need to post it unsder the Member's Photo area. It you can post it to the web, find the www...... link and in your post find the icon above which shows enter and image. Let me know if you need more.
Posts: 110 |
Please except my THANK YOU! You all tried to help me but I was wrong in my description etc. I now understand that the plate/hole I was referring to was the plate just forward (towards the engine). I believe that the whole there is correct. The trans oil coming out that hole is draining from my trans---PROBLEM! looks like I must pull the trans and reseal! Any other suggestions?
Posts: 1,919 |
OK, it sounds like your talking about the Flywheel bottom cover which has a hole in the bottom.
So most likely your cluster shaft is leaking or your front bearing is leaking. Take the transmission apart and use gas tank sealer when installing the lower shaft. Put it around the hole before you slide the shaft in and then coat the outside when finished.
As to the bearing, get a sealed bearing and remove the inside seal and keep the out seal. This way you can get oil to the bearing from the transmission.
You can PM if you want more details.
