Posts: 58 |
My 1928 coupe couldn't climb a 15 degree hill in my town. I read on VCCA that a lot of you switched to a 3077 Autolight plug . I did yesterday and WOW what an improvement!!! thanks for the info. respectfully trooper
Posts: 1,049 |
Trooper have you done a compression test or vacuum test? I got 3077 plugs and they work great. Ken
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
Posts: 1,284 |
Until I made the change to 3077's I thought it was just personal preference, but after just 3 weeks I'm a believer.
Ray
Posts: 58 |
Ken: Yes I have done a compression-the #1 are 65 and the #3 are 70psi. The Vac. is 17 Hg with a slight flutter.I am very happy and now I can go to our town center and order some gas,by the way the gas station is also a F**D Dealer. respectfully trooper
Posts: 1,049 |
Posts: 802 |
Now if you want some real hill climbing fun , bring your car to the Newport Antique Auto Hillclimb in Newport Indiana. Part of the hill at the top gets to about 18% grade and it is a city street. A LOT of fun! http://www.newporthillclimb.com/
28 Chevy LO Capitol 1 ton, 28 National 2 dr coach, 71 Chevy Custom Camper 3/4 ton. Also 23 Oldsmobile Economy truck and a 24 Olds sport touring.
Posts: 173 |
For those of you who are running a #3077 spark plug. Is the side electrode suppose to be along side of the center electrode so that it sparks at say a 90 degree angle or should the side electrode be inline with the center electrode and sparks "inline" with the electrodes? My assumption is the 90 degree angle, just looks a bit different to me. Also, what gap do you guys gap them at? I am thinking .040, but could be wrong.
Cheers, Gary
Do not change the configuration of the plug. Set the gap side to side. .040 will work.
Posts: 1,284 |
Hi Ray,
Good subject to talk about, as I run my gap on my 3077's at 30 thou.
Have you settled on 40 thou as a result of testing, and did you detect a distinct difference.
Would the bigger gap, bigger spark place more load on the points and coil.
Regards
Ray
I could live with the .035 to .040. Whatever works the best for the particular engine. We always assume that the remainder of the system is operating at top efficiency. If it breaks down, it just wasn't meant to be.
