I just replaced the wood on all 4 of my doors for a 29. The main thing I can say is when you clamp the metal back down to the wood before you start nailing, have a piece of straight wood that extends all the way across the piece you are clamping down before you start nailing. Make sure the metal pulls up evenly and with good line of sight. My wood was out of the doors for several months, sand blasted, primed and hauled across the country before they were put back together. I had the benefit of working with Jim Rodman at Autowood Restoration while we put them back together. Afterward it was a great experience.
