Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
I have a 1951 Chevy, 3 speed. It had a 216.
My '51' now has a 1955 235 engine.
How can I tell if the distributor being used in the 235 is the 216 OR the 235 distributor?
Thanks,
Bob
Posts: 260 |
The '51 dist. would be # 1112362 or 363.The '55 distributor would be # 112403. Neil
have a nice day
Posts: 260 |
Sorry missed a 1 -should be 1112403. Neil
have a nice day
The '51 dist. would be # 1112362 or 363.The '55 distributor would be # 112403. Neil Thanks for the numbers, Lucky .... is there a difference in the physical appearance of the 2 distributors? I was looking at Pertronics and saw comments about "tall cap" or "short cap". It's all not clear to me.
Posts: 260 |
The '51 dist. used what I'd call a low profile cap. The '55 is much taller. Neil
have a nice day
The '51 dist. used what I'd call a low profile cap. The '55 is much taller. Neil Ok Neil, that is what I'm looking for, thanks ! bob
Posts: 2 |
I have a '55 engine in my '54. What are the differences in these distributors? Don
Posts: 260 |
Points, rotor, condenser and dist. cap the same. Vacuum control different. I think the weights are the same. Neil
have a nice day
The '51 dist. used what I'd call a low profile cap. The '55 is much taller. Neil Lucky 1, Are the points, condenser and rotor the same on the 51 and 55 distributor? Bob
Posts: 260 |
The rotor is different. Neil
have a nice day
The rotor is different. Neil So, rotor and cap different, cap is taller on 235. Points and condenser the same. Thanks Lucky 1. Bob
Posts: 260 |
You're welcome and correct. Neil
have a nice day
Does anyone have a photo of the 1955 235 distributor, showing a view from the cam gear to the cap? I'm unable to locate a good photo, showing the view I would like.
Thanks, Bob
