Posts: 25 |
Does anyone know where I can get any original or remanufactured 12 volt Delco Remy coil for my 1966 396 BB? Tony
Posts: 11,162 |
I ocassionaly buy from Rockauto.com. This should take you to the proper page for the Delco Remy coil for your 66 396 engine Rockauto delco coil ![[Linked Image from images.wrenchead.com]](http://images.wrenchead.com/smartpages/partinfo_resize/DUS/E552C.jpg)
Posts: 49 |
do you want a real AC Delco coil? NOS or reproduction?
Posts: 11,162 |
If you want the Delco Brand, that is what I looked up. You can find as good a coil at NAPA or your local home owned auto supply store, just won't always be branded Delco Remy or as they are now AC Delco.
Posts: 25 |
Do they make a repro w/the Delco name? Tony
Posts: 25 |
Posts: 25 |
Posts: 11,162 |
Posts: 49 |
I know they reproduce them for Corvettes in the same number on the coil that came on the car. check on ebay I seen lots of NOS ones for sell and the reproductions also.
