#153550 10/02/09 10:00 PM
Does anyone know where I can get any original or remanufactured 12 volt Delco Remy coil for my 1966 396 BB?
Wilwood Engineering1955-1957
I ocassionaly buy from Rockauto.com. This should take you to the proper page for the Delco Remy coil for your 66 396 engine Rockauto delco coil
[Linked Image from images.wrenchead.com]
Your local NAPA store should have the coil.
do you want a real AC Delco coil? NOS or reproduction?
If you want the Delco Brand, that is what I looked up. You can find as good a coil at NAPA or your local home owned auto supply store, just won't always be branded Delco Remy or as they are now AC Delco.
Do they make a repro w/the Delco name?
thank you
thanks
AC Delco won't do?
"Delco" is a registered trademark and to reproduce a coil with the "Delco" name on the case would require that the company making the coil would have to be licensed through GM. However, you can still get new "Delco" coils.
I know they reproduce them for Corvettes in the same number on the coil that came on the car. check on ebay I seen lots of NOS ones for sell and the reproductions also.
