#15258 10/21/05 12:47 PM
xxx Offline OP
I think this might have been answered before but I have forgotten (senior moment)....
For a '32 Chevy, is the instrument cluster area painted or do you use the art deco decal? Does the build date make a difference as to which way you should go (if there are 2 ways it was done)? If painted what color (body color or ?)?
Hey Gator! We have covered this in detail several times before. You can do a search on Chevy Chatter and check the past postings on the subject. :cool2: laugh laugh laugh
Come on JYD, be a good doggie, tell the Lad, don't make him do that old search thingy......
Not a chance....it's like the radio thingy....we have been through this too many times already. ha ha! wink laugh bigl bigl bigl
bigl bigl bigl bigl bigl bigl
With all do respect Gator.
If we ever need a can of worms you've got 'em.
Keep up the good conversation...we love ya man!
Chat Group Chapter Member
Current rides;
1968 Camaro rs/SS 350 4spd
2000 Blazer LT
2005 Malibu Maxx
2007 Acura TDX
Last total restoration;
1932 Sport Coupe
xxx Offline OP
Sounds so easy to "Use the search" however since most people don't put the correct name or year in the string title (or in message) it is difficult to find information...sure would help if people did. These are the results of searches so far:
Search “instrument cluster”- entire message, all categories =
oil press line bracket.
July 21, 2005July 21, 2005
1929-32
'32 instrument cluster
October 21, 2005October 21, 2005
1929-32
Defroster cover 38 Master Deluxe
December 24, 2002December 24, 2002
1937-42
Instrument Cluster 1939
October 13, 2004October 13, 2004
1937-42
wiry joe
December 06, 2004December 06, 2004
1937-42
Rewiring
September 28, 2005September 28, 2005
1937-42
Remove the entire dash on a 63 Impala
September 10, 2004September 10, 2004
1961-64
39 Speedo Needle
June 08, 2004June 08, 2004
Mechanical - Engine, Trans, etc
All gauges quit
May 27, 2005May 27, 2005
Electrical - 12 volt
Chevrolet Speedster ???
August 09, 2005August 09, 2005
1912-1928
1950 sedan parts
July 16, 2005July 16, 2005
PARTS - For Sale
Oil leak at dash on 59 Aache
March 02, 2005March 02, 2005
Chevy Trucks
Search “’32 dash”-entire message, all categories =
DELUXE OR STANDARD??
June 04, 2002June 04, 2002
1929-32
'32 Wiper Motor - Just Info...
July 18, 2002July 18, 2002
1929-32
Hershey PA Car Show
October 13, 2003October 13, 2003
1929-32
Fashion statement?
November 25, 2003November 25, 2003
1929-32
Freewheeling Tag
February 25, 2005February 25, 2005
1929-32
Gorgeous Gray 32
October 04, 2005October 04, 2005
1929-32
Got Heat?
November 18, 2002November 18, 2002
modern paint code
November 22, 2002November 22, 2002
Body - Sheet Metal, Paint & Wood
'32 interior
October 17, 2002October 17, 2002
Upholstery - Interiors & Glass
ash tray ring
November 19, 2002November 19, 2002
PARTS - Wanted
I will try, try and try again.
May 20, 2003May 20, 2003
PARTS - Wanted
Chevy radio?
June 14, 2005June 14, 2005
Radios, Tools, Accessories
Can I afford it???????????
September 10, 2003September 10, 2003
General Discussions
Any idea on what term I should use in a 'search'???
xxx Offline OP
Search for “dash paint” … all sections, entire message
Dash color
1929-32
Gorgeous Gray 32
1929-32
38 Wiper tranmission replacement
September 26, 2005September 26, 2005
1937-42
'54 belair with two lighters?
August 04, 2005August 04, 2005
1949-54
31 chevy
1929-32
Dash Paint Question
June 30, 2005June 30, 2005
Toggle Heater Switches on 39
June 10, 2005June 10, 2005
Electrical - 6 volt
52 chevy dash paint
May 31, 2005May 31, 2005
1949-54
50 Chevy interior dash colors
May 30, 2005May 30, 2005
1949-54
39 Chev rose tan paint
May 18, 2005May 18, 2005
1937-42
Turn signal switch on ebay
April 26, 2005April 26, 2005
1946-48
1951 Wagon Paint Colors Question
March 21, 2005March 21, 2005
1949-54
Dash removal in 46 pickup
March 19, 2005March 19, 2005
23 Ignition Switch
March 15, 2005March 15, 2005
1912-1928
'32 colors?
March 14, 2005March 14, 2005
1929-32
Radio Installation Kit
March 10, 2005March 10, 2005
Under the skin...
March 04, 2005March 04, 2005
1929-32
53 Chevy 1/2 ton interior color
February 06, 2005February 06, 2005
'34 Chevy 1/2 ton interior questions
January 29, 2005January 29, 2005
1933-36
1939 Grille
January 26, 2005January 26, 2005
1937-42
What term should I try next?
Or is the answer in one of these...don't have the time to read all of them...if you know where the answer is let me know.
xxx Offline OP
“art deco” 29-32 only search … 4th string and 12th are close to the answer to my question, but not complete.
1929-32
31 wiring harness--cabriolet
September 27, 2005September 27, 2005
1929-32
crank shaft oil leak
September 10, 2005September 10, 2005
1929-32
1932 dash
January 13, 2005January 13, 2005
1929-32
31 chev starter problems
January 10, 2005January 10, 2005
1929-32
decoding assembly origin
April 29, 2004April 29, 2004
1929-32
Hershey PA Car Show
October 14, 2003October 14, 2003
1929-32
Steering wobbles
July 11, 2003July 11, 2003
1929-32
1930 2-door sedan
November 14, 2002November 14, 2002
1929-32
Right year, different model headlight...?
September 13, 2002September 13, 2002
1929-32
Fuel Pump Rebuild
September 07, 2002September 07, 2002
1929-32
1929-32
'31 Roadster Story
May 10, 2002May 10, 2002
1929-32
xxx Offline OP
Different things have been said on different strings....deluxe vs. standard, depends on what factory built car, before April vs. after April, different models done different, etc.
I just want to know if a standard cabriolet built in Dec. '31 should have the art deco decal or have paint in the instrument panel cluster; and what color paint?
Or is this a question that has no correct answer??? Dealer's choice, maybe?
Gator, It looks like you have all the answers!
Remember what __________ said:
"If I'm in doubt, I paint it black".
wink
Gator.....we have talked about this several times before. If the Art Deco transfer was not used the recess was usually painted body color. It all depends upon your paint number as to what color the recess was. Your cabriolet was an early production so the Art Deco transfer was not used. Write this down so that you don't forget. ha ha! laugh laugh laugh laugh
xxx Offline OP
Good, as long as the judges know this information too...remember it is paint 95...car was bought in SC, would that help with what factory made the car?
For information sake...why do you say "usually painted body color", was there another something else done?
"Good, as long as the judges know this information too".
Good luck with that one. laugh laugh laugh
Paint only the recess area.
xxx Offline OP
So the ridge has no body color paint on it, just the flat recess area, right?
Thanks guys...
I think you got it this time.
xxx Offline OP
Chipper, from your comment I guess you found the answer to my question on a search....I sure couldn't find it...what term did you search with?
It's too bad about paint and no decal , I sorta like the look of the art deco decal....oh well, original is original...but then again on the other hand, if....
Thanks guys.
Gator, you said: "So the ridge has no body color paint on it, just the flat recess area, right?"
Chipper Dipper replied: "I think you got it this time."
I think that Chipper Dipper was basically agreeing with you that "yes, you have it right, the ridge has no body color paint on it, just the flat recess area." I don't think that it had anything to do with a search since he was just agreeing with your answer. yipp laugh laugh laugh
:confused: :confused: :confused: :confused: :confused: :confused:
xxx Offline OP
OK...thanks
