Posts: 3,542 |
I think this might have been answered before but I have forgotten (senior moment)....
For a '32 Chevy, is the instrument cluster area painted or do you use the art deco decal? Does the build date make a difference as to which way you should go (if there are 2 ways it was done)? If painted what color (body color or ?)?
Posts: 11,162 |
Come on JYD, be a good doggie, tell the Lad, don't make him do that old search thingy......
Posts: 11,162 |
Posts: 2,073 |
With all do respect Gator. If we ever need a can of worms you've got 'em. Keep up the good conversation...we love ya man!
Chat Group Chapter Member Current rides; 1968 Camaro rs/SS 350 4spd 2000 Blazer LT 2005 Malibu Maxx 2007 Acura TDX Last total restoration; 1932 Sport Coupe
Posts: 3,542 |
Sounds so easy to "Use the search" however since most people don't put the correct name or year in the string title (or in message) it is difficult to find information...sure would help if people did. These are the results of searches so far:
Search “instrument cluster”- entire message, all categories = oil press line bracket. July 21, 2005July 21, 2005 1929-32
'32 instrument cluster October 21, 2005October 21, 2005 1929-32
Defroster cover 38 Master Deluxe December 24, 2002December 24, 2002 1937-42
Instrument Cluster 1939 October 13, 2004October 13, 2004 1937-42
wiry joe December 06, 2004December 06, 2004 1937-42 Rewiring September 28, 2005September 28, 2005 1937-42 Remove the entire dash on a 63 Impala September 10, 2004September 10, 2004 1961-64 39 Speedo Needle June 08, 2004June 08, 2004 Mechanical - Engine, Trans, etc All gauges quit May 27, 2005May 27, 2005 Electrical - 12 volt Chevrolet Speedster ??? August 09, 2005August 09, 2005 1912-1928
1950 sedan parts July 16, 2005July 16, 2005 PARTS - For Sale
Oil leak at dash on 59 Aache March 02, 2005March 02, 2005 Chevy Trucks
Search “’32 dash”-entire message, all categories =
DELUXE OR STANDARD?? June 04, 2002June 04, 2002 1929-32
'32 Wiper Motor - Just Info... July 18, 2002July 18, 2002 1929-32 Hershey PA Car Show October 13, 2003October 13, 2003 1929-32 Fashion statement? November 25, 2003November 25, 2003 1929-32 Freewheeling Tag February 25, 2005February 25, 2005 1929-32 Gorgeous Gray 32 October 04, 2005October 04, 2005 1929-32 Got Heat? November 18, 2002November 18, 2002 Mechanical - Engine, Trans, etc
modern paint code November 22, 2002November 22, 2002 Body - Sheet Metal, Paint & Wood
'32 interior October 17, 2002October 17, 2002 Upholstery - Interiors & Glass ash tray ring November 19, 2002November 19, 2002 PARTS - Wanted
I will try, try and try again. May 20, 2003May 20, 2003 PARTS - Wanted
Chevy radio? June 14, 2005June 14, 2005 Radios, Tools, Accessories Can I afford it??????????? September 10, 2003September 10, 2003 General Discussions
Any idea on what term I should use in a 'search'???
Posts: 3,542 |
Search for “dash paint” … all sections, entire message
Dash color October 21, 2005October 21, 2005 1929-32
Gorgeous Gray 32 October 04, 2005October 04, 2005 1929-32 38 Wiper tranmission replacement September 26, 2005September 26, 2005 1937-42 '54 belair with two lighters? August 04, 2005August 04, 2005 1949-54 31 chevy July 21, 2005July 21, 2005 1929-32 Dash Paint Question June 30, 2005June 30, 2005 Body - Sheet Metal, Paint & Wood Toggle Heater Switches on 39 June 10, 2005June 10, 2005 Electrical - 6 volt 52 chevy dash paint May 31, 2005May 31, 2005 1949-54 50 Chevy interior dash colors May 30, 2005May 30, 2005 1949-54 39 Chev rose tan paint May 18, 2005May 18, 2005 1937-42 Turn signal switch on ebay April 26, 2005April 26, 2005 1946-48 1951 Wagon Paint Colors Question March 21, 2005March 21, 2005 1949-54 Dash removal in 46 pickup March 19, 2005March 19, 2005 Upholstery - Interiors & Glass 23 Ignition Switch March 15, 2005March 15, 2005 1912-1928 '32 colors? March 14, 2005March 14, 2005 1929-32 Radio Installation Kit March 10, 2005March 10, 2005 Radios, Tools, Accessories Under the skin... March 04, 2005March 04, 2005 1929-32 53 Chevy 1/2 ton interior color February 06, 2005February 06, 2005 Body - Sheet Metal, Paint & Wood '34 Chevy 1/2 ton interior questions January 29, 2005January 29, 2005 1933-36 1939 Grille January 26, 2005January 26, 2005 1937-42
What term should I try next?
Or is the answer in one of these...don't have the time to read all of them...if you know where the answer is let me know.
Posts: 3,542 |
“art deco” 29-32 only search … 4th string and 12th are close to the answer to my question, but not complete.
31 wiring harness--cabriolet September 27, 2005September 27, 2005 1929-32
crank shaft oil leak September 10, 2005September 10, 2005 1929-32
1932 dash January 13, 2005January 13, 2005 1929-32
31 chev starter problems January 10, 2005January 10, 2005 1929-32
decoding assembly origin April 29, 2004April 29, 2004 1929-32
Hershey PA Car Show October 14, 2003October 14, 2003 1929-32
Steering wobbles July 11, 2003July 11, 2003 1929-32
1930 2-door sedan November 14, 2002November 14, 2002 1929-32
Right year, different model headlight...? September 13, 2002September 13, 2002 1929-32
Fuel Pump Rebuild September 07, 2002September 07, 2002 1929-32 DELUXE OR STANDARD?? June 04, 2002June 04, 2002 1929-32
'31 Roadster Story May 10, 2002May 10, 2002 1929-32
Posts: 3,542 |
Different things have been said on different strings....deluxe vs. standard, depends on what factory built car, before April vs. after April, different models done different, etc.
I just want to know if a standard cabriolet built in Dec. '31 should have the art deco decal or have paint in the instrument panel cluster; and what color paint?
Or is this a question that has no correct answer??? Dealer's choice, maybe?
Posts: 11,162 |
Gator, It looks like you have all the answers! Remember what __________ said: "If I'm in doubt, I paint it black".
Posts: 3,542 |
Good, as long as the judges know this information too...remember it is paint 95...car was bought in SC, would that help with what factory made the car?
For information sake...why do you say "usually painted body color", was there another something else done?
"Good, as long as the judges know this information too". Good luck with that one.
Posts: 221 |
Paint only the recess area.
Posts: 3,542 |
So the ridge has no body color paint on it, just the flat recess area, right?
Thanks guys...
I think you got it this time.
Posts: 3,542 |
Chipper, from your comment I guess you found the answer to my question on a search....I sure couldn't find it...what term did you search with?
It's too bad about paint and no decal , I sorta like the look of the art deco decal....oh well, original is original...but then again on the other hand, if....
Thanks guys.
Gator, you said: "So the ridge has no body color paint on it, just the flat recess area, right?" Chipper Dipper replied: "I think you got it this time." I think that Chipper Dipper was basically agreeing with you that "yes, you have it right, the ridge has no body color paint on it, just the flat recess area." I don't think that it had anything to do with a search since he was just agreeing with your answer.
Posts: 11,162 |
:confused: :confused: :confused: :confused: :confused: :confused:
Posts: 3,542 |
