Posts: 81 |
G'day, where is the best place to get points for a '26? Cheers Jimmy
Posts: 2,418 |
Could you explain this somewhat more, please?
:vcca:
Solan G, # 32797
Posts: 597 |
I think he is just looking for a vendor, like Gary Wallace or the Filling Station
It's not how fast you can go, but how good you look at 20 MPH.
Posts: 2,418 |
He will get such points by both the mentioned companies.
:vcca:
Solan G, # 32797
Posts: 81 |
:vcca: distributor points. Shawng, thanks. Jimmy
Posts: 127 |
Hey Jimmy
Arnt you running a 25 motor in that roadster of yours. There seems to be a huge difference between prices for early and late distributor parts. Someone on ebay is advertising 1925 cap rotor and points for $150 US!!. You can buy a house and a few acres by the sea in NZ for that. The same parts for 1928 dizzi are much cheaper and I think you can fit them to 26 & 27 motors and you get the advantage of the auto advance. Just a thought.
Ken
Posts: 814 Likes: 1
Posts: 814 Likes: 1 |
There is a big difference in price between points for a generator driven 366P then a cam driven 374A. which one are you looking for???
Posts: 81 |
G'day Ken, I have a '26 motor that only needs points so I am using that till I can afford to rebuild the '25. Prices are expensive if I could get a good '28 distributor & cap I could use the new points out of my '29 motor. Cheers Jimmy Hey Jimmy
Ken
Posts: 809 |
The points from a 28 and late 27 will NOT fit an early 27 or any model 26. Also a late 27 or 28 distributor will not go in a 26 block or an early 27 block Chris
Posts: 81 |
The points from a 28 and late 27 will NOT fit an early 27 or any model 26. Also a late 27 or 28 distributor will not go in a 26 block or an early 27 block Chris Chris, thanks for the info. Do you know of anyone who sells '26 points in Australia? Cheers Jimmy
Posts: 809 |
No but there are plenty on ebay Chris
Posts: 127 |
can someone explain why the 28 distributor (635B) cant be adapted to a 26 engine block.
Posts: 845 |
The 1927 and 1926 distributors are secured in one position only. If you look at the '26/'27 block below the distributor entry hole you will see a threaded set screw held in place by a jam nut. This threaded screw is tapered at the inner end and fits into a tapered hole in the distributor main column. There is a second similar set screw/jam nut arrangement below the one mentioned that holds the oil pump in position. On this system timing is altered by removing the distributor cap and rotor, loosening a jam nun on the upper end of the main shaft and rotating the four lobed cam about its tapered seat one way or the other and securing the jam nut. The base plate which holds the points is designed with some rotational movement and is attached to the mechanical linkage of the steering column.
The 1928 engine block has an added embossment at the distributor entry hole location which is machined flat 90º to the distributor shaft. There is an additional clamp type device that is secured to this flat surface and inturn clamps to the distributor main column. Timing on this system is accomplished by loosening the clamp and rotating the distributor within the clamp. There is no set screw/jam nut for the distributor on this system but the oil pump set screw/jam nut is still used and can be seen below the distributor assembly. The distributor base plate (plate that the points are attached to) on this system is fixed in position and does not move with respect to the distributor. The clamp that holds the distributor in place has a provision for some rotational movement and is attached to the mechanical linkage of the steering column.
Posts: 127 |
Brilliant. Thanks for that Oldie. crystal clear now.
Posts: 127 |
so lets clarify - if you can work out a way of preventing the 635B from jumping for freedom from the 1926 block perhaps by way of a customized bracket using the set screw maybe, and the installation of a suitable advance retard mechanism, a 28 dizzy could be made to operate in a 26 block or is the degree of advance and retard achievable with the 635B inadequate?. I realize such questions a blasphemy to the purist but humour me, this is purely an academic if somewhat naive question.
Posts: 513 |
Oldie have explain it a splendid way. I think you can use a 635B if you can made a suitable bracket for the hold down screw (A).
Posts: 1,213 |
The distributor advance in degrees for the early '26/'27 374-A distributor(which is a full manual advance/retard type)is 30 degreess nominally,but I have seen and repaired some that have a 25 degree advance limiting plate,though this may be from the even earlier 366-P distributor. The 635-B distributor has an automatic centrifugal advance of 20 degrees which starts to come into effect at speeds over 22mph.this coupled with the initial spark setting of 25 degrees before top dead centre,would more than likely could pinging,pre-ignition and over heating in a '26. It could be done,but to get the initial ignition setting would be pure experimentation,and if not correct,may cause a severe enough backfire to wreck your starter motor.
CJP'S 29
