Hi , This is the grease monkey 123 I removed and installed new rocker panels.
The ones I took off and the ones I installed did not have holes in them. The clips I bought have 1 screw hole in them and 2 tabs coming out of the back. I looks to me like the tabs should go into the rockers. To do this I would have to drill holes. The Question. Did the factory ones have holesin the rockers for the clips or are the clips I have could be used for other model chevy. Do I grind the tabs off and just install the clips with 2 screws?
Any info would be appreciated Thanks
