#137988 03/03/09 12:05 PM
trooper Offline OP
Thanks for the response for carb, now I need a working light switch. thanks trooper
For a better response on the light switch that you are looking for you might want to post this in the "Parts Wanted" forum instead.
What is it about your headlamp switch that isn't working? They are restorable most of the time. New handles (around $40) and face plates(around $10) can be purchased from Gary Wallace.
trooper Offline OP
Hi: I've replaced the handle and faceplate from Gary. I hook it up to a spare battery. Pos. to Bat. Using a Multi Meter from the different terminals there is no flow. Now the metal tabs are breaking off. Want a working one. Thanks for your response. trooper
I made new switch condacts from a piece of copper from a hoby store. It took some time but it works.
Listen to the "click'n" of those push rods
Trooper. There is a 1927 headlight switch on EBAY. It may be the same as a 1928. Good Luck.
Item number: 250384411875
Steve
Not the same. Send me a PM.
Agrin devil
trooper Offline OP
Ray: The mounting tabs are different, but the are similiar. Thanks for your response. trooper
