Posts: 58 |
Thanks for the response for carb, now I need a working light switch. thanks trooper
Posts: 845 |
What is it about your headlamp switch that isn't working? They are restorable most of the time. New handles (around $40) and face plates(around $10) can be purchased from Gary Wallace.
Posts: 58 |
Hi: I've replaced the handle and faceplate from Gary. I hook it up to a spare battery. Pos. to Bat. Using a Multi Meter from the different terminals there is no flow. Now the metal tabs are breaking off. Want a working one. Thanks for your response. trooper
Posts: 154 |
I made new switch condacts from a piece of copper from a hoby store. It took some time but it works.
Listen to the "click'n" of those push rods
Posts: 814 Likes: 1
Posts: 814 Likes: 1 |
Trooper. There is a 1927 headlight switch on EBAY. It may be the same as a 1928. Good Luck. Item number: 250384411875
Not the same. Send me a PM.
Posts: 58 |
Ray: The mounting tabs are different, but the are similiar. Thanks for your response. trooper
