tazmo Offline OP
I removed the broken piece from the outer side(wheel/brake side, is the splined side bolted in or does it just slide out? thanks
No it is not bolted at the inner end, the axle just slips into
the small differential gear splines.
JACK
Yes, as jack39rdstr stated the axle shaft just slips into the differential gears, however, when the axle shaft breaks in the middle sometimes it is a little difficult to "fish" the splined end out of the axle housing.
a easy way to pull out the inner half of a broken axle ia to use a chinese finger -- I have several times and it sure saves time
Don Bergholm
This is probably a stupid question, but what exactly is a chinese finger?(somebody had to ask this one)
Its commonly used to pull the rope type rear main bearing seal in place on later models.
Lets put it this way. Its a loosely woven mesh just large enough to go around a round object.
as it is pulled on (to remove the object) the opening gets smaller and grips the object. The harder you pull the tighter it grips.
A friend of mine used a peice of PVC pipe that would fit over the axle. Tap it on and pull the broken half out. He had good luck doing it that way. Good luck with your project.
Sal Orlando
Chat Group Region Member
