Posts: 1,136 |
The original '32 luggage rack is correct for what other years, if any?
Thanks.
1931 and with different length brackets it is correct for 1930 as well.
Posts: 1,136 |
Thank you very much Chipper.
For a '30 would the arms need to longer or shorter?
Thanks again...
Do you have a 1930 Gator?
:) :grin:
Posts: 1,136 |
No, I don't Skip but another member of the VCCA has a '30 and he wants to buy my rack and I need to know if he can use it or modify it or ?, thanks for any help you can give me.
Posts: 1,136 |
Any help??
If a '31-'32 rack is different than a '30 rack, how different is it and how hard would it be to modify it to fit?
Thanks...
The mounting arms are different length for the 1930 rack compared to the '31-32 luggage racks.
Posts: 1,136 |
Thanks Chipper, would he have to lengthen them or shorten them? Do you know how much?
Anyone got a '30 rack that they can measure the arms?
Lots of questions come to mind...if I remember right the long arms are made of 2 pieces of flat stock and 1 piece of flat stock; would he have to cut/add to the 2 or the 1?
Thanks again for any help.
Posts: 36 Likes: 1
Posts: 36 Likes: 1 |
I made mine 7 1/2" c/c on the bottom arm to have the rack be perfectly level when a trunk is mounted on it. It's tricky getting it right because there are 2 bends and it's riveted at both ends. Done right it turns out nice. The upper is the same 30-32 because it rests at a specific spot when in the upright position. Nineteen thirty has a flat gas tank apron, 31 and 32 aprons are recessed, hence the different length arms.
I've driven my car almost 30,000 miles
I will need to measure them. It will take a couple of days to get 'er done.
Posts: 1,136 |
Thanks guys that is great help. Have a great weekend.
