#478269 01/29/23 04:04 PM
I have broken down the trans on my 28. there seems to be a steel wrap on the counter shaft between the 31 tooth and 25 tooth gears. does anyone what it is for? Also it is bent up, it appears to give access to the oil hole for the bushings and shaft. I have looked for anything similar but can't seem to find any counter shaft gears that have this configuration. My thought is maybe it is there to splash lube up and around? Next question is it necessary for the function of the transmission?
It's a "spacer", part #328670,
and it looks like it's supposed to be shaped that way, so it looks like you are good to go. :-)
Ole S Olson
And...
yes it should be there... to catch and feed oil into the counter shaft bushings inside it when it rotates.
Ole S Olson
Awesome! Thank you!
A little more cleaning and new bushings then back together she goes! This was a spare I picked up along with the engine. My current one is going to be next, she is clunking pretty hard but only in first gear.
Support The VCCA!
Member Photos
1948 woodie
1948 woodie
by firecars, March 7
1918 D5 V8 pictures
1918 D5 V8 pictures
by Mel1940, November 18
Progression on the 64 Impala SS 409
by DreamChevy, October 21
1964 Chevrolet Impala SS 409/425
by DreamChevy, October 10
Who's Online Now
6 members (Heinz, wannchev, ruscar, kaygee, firecars, 1 invisible), 25 guests, and 49 robots.
Key: Admin, Global Mod, Mod
Newest Members
41Fred, LarryBrauer, Thilo, robertwight, Iggly
17,811 Registered Users
Today's Birthdays
28chev rebuild, MrMack
Forum Statistics
Topics57,539
Posts420,292
Members17,811
Most Online1,133
Jan 22nd, 2020
