transmission question - 01/29/23 08:04 PM
I have broken down the trans on my 28. there seems to be a steel wrap on the counter shaft between the 31 tooth and 25 tooth gears. does anyone what it is for? Also it is bent up, it appears to give access to the oil hole for the bushings and shaft. I have looked for anything similar but can't seem to find any counter shaft gears that have this configuration. My thought is maybe it is there to splash lube up and around? Next question is it necessary for the function of the transmission?
